Suspension Torque Specs
mrpanic7
I searched and searched and could not find the answer in any threads...
I'm doing the FJ shock/spring swap, and want to know specific torque specs for the suspension parts I'll be loosening and putting back plus the sway bar since I'm upgrading the bushings.
Anybody have the specs or thread with em? I found the RedLoctite 166 lb ft for those 2 bolts that connect to the hub but that's it. Thanks
No I only removed the sway bar.
I really only used those PDF's for the torque values and to make sure I had the bushings and retainers on the in correct order. I didn't use the steps listed in them for r&r of the shocks and springs, I used the 'no spring compressor' method write up that's floating around.
Thanks you rock:trophy:
