Sway Bar Bracket Dimensional Details
NW.OH.T4R
I don't like opening a new thread for a seemingly straightforward question, but I'm curious if anyone has the hole-to-hole center-line dimensions for our sway bar brackets? Specifically looking for the 30mm front, and 20mm (non-KDSS) rear. I measure ~3" for the rear, but this is installed, so not sure how accurate I am.
You talking link measurements. I have both stock front and rear links I just took off, & I could post some photos and measurement of links if this is indeed what you’re looking for
Not the end links, but the brackets that hold the sway bar bushings. Like these:
Reason - I’ve reached out to ride tech based on another member’s post to try to get front and rear replacement delrin-lined bushings with billet aluminum brackets. They typically service GM cars and trucks, so aren’t well versed in our brackets.
10-4, well I’m now interested. Will be following this as it develops!
Ironman 4x4 also makes the bracket (at least front), but ride tech pricing seems to be similar to Ironman plus you can get the Delrin bushing with the bracket.
Had some time today while the little one was napping and grabbed measurements. Front and rear are apparently the same dimensions on-center. New measurements are ~82mm or just under 3 1/4"
