Sway Bar end link pair.
Auce
I need a pair. From my understanding its a non-critical part? So aftermarket should be fine? Any recommendation's for a pair on a budget? Thanks.
Rockauto.com. I bought some AC Delco sway bar end links on there that have a greaseable zerk, are twice the thickness of OEM ones and were half the price. Win-win-win.
Link? PN? Lifted or stock height?
IiRC I am running second gen OEM...
Better yet do you have the link with the ones with the greaseable zerk please?
Sold as a pair, usually yes
Pic on their site, AC Delco Gold PN 45G20513, doesn't show grease fitting and the description says NOT greasable
MevoTech ones are also oversized and greasable
MOOG end links are very beefy and also have the zerk fittings. They cost a little more but they are worth it. Have you also took a look at the sway bar bushings? They might need replacement as you said everything is original.
I almost aways use moog sway bar links. Grated I have one with a 2 inch suspension lift from a PO. Not exactly sure which links to use in it. Not sure if the stock height ones are the best option for it. :)
Sent from my SM-A505U using Tapatalk
I think anything greaseable. Mine are either Napa or advanced auto. Napa is go to number 1 and advanced is number 2 for non OEM stuff.
I removed my front swaybar completely on my 3rd gen, feels like a stock 2nd or 4th gen til you hit wind. I found a thread saying you can use 2nd gen links on 4th gens, and my buddies use them on their 3rd gens aswell, same thread recommended Jeep JK links and cutting to size. Rear sway bar endlinks
MMJR_T4R
