Rear sway bar endlinks
T4R916
What are you guys using? I have an adjustable heim endlinks but they squeak all the time when its dry. Tired of spraying lithium grease on it every 2 days
Newb question, but what to the rear sway bar endlinks do for you? I think I've got my head pretty well wrapped around the front IFS, but this is the firs time I've had something with a 4 link rear as opposed to leaf springs.
I used Jeep JK end links. You have to cut one end off to desired length and thread. Add bushings, washer, and a nut and you have a sealed end link.
Are you lifted? I have a 3in lift and I use the JKS 2000 quick disconnect adjustable links. Perfect size. No cutting.
Dexterforme
