Sway Bar Links - Eugene, OR
I sent an email from the website before seeing this thread. I'm looking to get rear extended links for 5th gen 4Runner and want to know if I could get red powder coat on the links or do black links with red bushings? LMK Thanks!
You can, and I just replied to your email too.
Mike
My new links are live on the site. Follow the link below, and get free shipping through the end of the year. Here's the link(s).
hi what the approximate stock length of these vs stock for 5th gen 4runners?
my shop tossed out my 4 month old dobinsons and installed moogs because the dobinsons failed.
Front links are slightly longer than OEM. The rear links around an inch longer than OEM, and adjustable beyond that.
Mike
Mike
thanks! ordered heims from you years ago, never installed them. ordered the balljoint ones. will get around to it this time!
$20 each plus $10 for shipping.
Mike
I quickly perused your site and it didn't jump out at me as an option - how do I go about ordering just the ball joint component to upgrade the rear heim links I already have? I'd like to upgrade my rears and then buy a full set for the front.
Sent from my SM-G965U1 using Tapatalk
Shoot me a PM. I don't have those parts on the site yet.
Mike
So I just purchased 2.5 fox's all around for the 14' SR5 runner and was wondering at what height would it be recommended to upgrade the sway bar end links?
I think I will be raising it to 2.5in to maybe 3in the front and it will be paired with aftermarket upper control arms.
As for the rear, just enough to level the ride with the front, I think 1.5in?
Would it make sense to switch out the front end links with the upgraded pair and keep the rear stock or would the increased height stretch the stock links too much?
Thanks in advance.
Thanks in advance.
Would make more sense the switch out the rear with an upgraded pair, and leave the front. The rear will be longer so you can get your sway bar back to its OEM position. The front links will be the same length as OEM, and you want it like that.
Mike
Is it possible to get replacement ball joints? I had the nut fall off one and mess up the threads pretty bad on one so I can't get a nut back on very far.
