Sway bar sizes?
2003V8LTD
For a 2009 V6 Limited 4wd, any idea what size the sway bars are?
My sway bar bushings are really worn out and I'm going to replace them. Everything is pretty clattery as you roll down the road and I've had good luck with past cars remedying that by replacing the sway bar bushings. I think I might as well try polyurethane bushings this time around ... firm things up a little.
By my crude measurement, the front bar is 30mm and the rear is 19. But the parts manual seems to suggest that the front is 29. In PU bushings you have to be bang-on with the correct size, apparently. Anyone know for sure what the sizes are?
AndiGarage
