Swaybar diameter Gen 6
Helixx
Hello,
Does anyone know if the Gen 6 all have the same diameter swaybars or do the versions with the swaybar disconnect option have a larger diameter swaybars installed (like the KDSS version used to have) offering better on road and offroad handling?
Thank you
Don't know the diameters, but ...
1. No more KDSS
2. On some models, sway bar has moved from the ahead of the front axel (5th gen) to behind the front axel (6th gen).
3. The sway bars are different diameter based on which model you get.
Car Care Nut said of the sway bar and links ...
"Its a very big sway bar link. I really like its location."
"And in certain trims, it will have a disconnecting front sway bar."
This vid shows a sway bar off the vehicle.
Front sway bar is much bigger diameter than rear sway bar.
https://www.youtube.com/watch?si=tobGl5B5CGOfBxGN&t=693&v=pPmpJoVy6MY&feature=youtu.be
Rear facing sway bar without disconnect
freddygino
