AlmightyMoonPie
Some of you guys crack me up. You will spend big bucks on the outside of your runners (Grinot's and Zanios) but still use plain oil. I have been in the environmental business for many years, and have connections to the Chevron Refinery in Mississippi. Most every oil is produced buy one of a few companies, TexacoChevron, and ExxonMobil are the big two, all the oil is the same except for the addition of additives, and you can only get one basic oil, that just the way the refining process works. Kind of like gas, it’s all the same except for the additives, However I am not talking about the octane rating.
I have been using AMSOIL for years in everything I have , from the lawnmower and weedeater and ATV, to the Miata and Jeep, I can tell you that there is a difference in the contamination build up in the synthetics, i.e. there is almost none, I change the oil in the cars every 7500 miles, It is wonderful. yes it is more expensive, you can sign up for a preferred customer for $20.00 a year and get it at the dealer price, and oil change that way only add bout $10.00 to the cost. plus you can get all of you grease and filters and even ATF, order on Monday and it is here buy Thursday, That why I don’t have to go out looking of the oil that I need. I usually order a years worth at a time, All I can say that it is good stuff. the only thing I dont run AMSOIL is in the diffrentals for that I use good ole LUCAS
When you 05 runner get here you better beleive that the only oil that I run will be AMSOIL.
MP
MP
