synthetic vs. conventional
Aside from all the really long posts here, I usually use synthetic (I don't think I have switch the 4runner over yet, but probably will) just because the change interval is longer. I have a long commute, and put miles on pretty quickly, so I hit 3k miles pretty quick.
Here's another question about conventional vs syn oils. Is there really any problem with switching back from synthetic to conventional? I have always heard that there is.
Nope there isn't any problem switching back & forth but I doubt that you will.
Especially if you put lots of miles on your 4runner quickly
Bottom line on this conversation between Nunyabiz and Singtoe:
Nunyabiz feels that his 4Runner deserves full synthetic. Singtoe feels his 4Runner works just fine with conventional. BOTH are correct...the problem is that everyone is trying to justify their feelings on this debate with numbers and fact and proof of this that or the other....when it's really all moot when each oil is used correctly.
Conventional oil, when changed regularly can easily lubricate and protect an engine for the life of the engine....and NOT be the cause of failure when the engine eventually dies or needs rebuilt. Some of the highest mileage engines in the world used conventional oil their whole life.
I just tore down a 100k mile engine that had used Quaker state conventional it's whole life, changed regularly. The engine and head look immaculate.
Synthetic is better. Conventional is plenty good enough. Its like playing a 3 man scramble in golf: yourself, Phil Mickelson and Dustin Johnson. Yes, Phil is better than Dustin...but Dustin works just peachy....cause he's still quite a bit better than necessary for playing the local tournament with amatuer golfers.
I've been using Motomaster Formula1 synthetic in all my vehicles for years now. It's made by Shell (as per MSDS sheet), it meets or exceeds GM's Corvette standards, for which Mobil1 is the factory fill, it is a full synthetic unlike Mobil1, and it goes on sale for as low as $16.99/4.4L jug. At that price, you get the benefit of synthetic, with the price of a quality dino-oil, it's a no brainer. I'm sure you guys in the US have a comparable option if you look around.
Sadly, it's not designed for diesel use, so I've been using Shell Rotella non-syn in the Surf, and I'll be doing 7500km intervals. Seems to be working just fine so far. I did use synthetic lubes for the diffs and transfer case when I changed them, and non-syn for the tranny when I did a few drain/fills.
All totally true
Nice analogy. Now you're speaking my language...
I primarily use synthetic for it's heat exchange stability properties when the going gets tough and I like my once a year or 9000 mile oil changes which saves me time and money and haven't used dino oil in almost 20 years.
This is why I love this forum. I'm not a mechanic, or mechanically inclined. But, this just makes sense to me. This whole time I've been thinking of the old adage "If it ain't broke don't fix it."
I run Amsoil these days. Mainly because it's very good oil and I can go 8-10k miles between changes. I also use Synth Tranny fluid, I tow a camper and heat can be a problem. Synthetic runs cooler, for the cost of an engine or transmission, I will stick with Synthetic.
The truth about motor oil
Here is a link from a consumer report test they did comparing synthetic to dino oil.
Happy reading.
Oil analysis
You know you can send your used oil off to Blackstone laboratories ( I think ), and have it analyzed for free. They will show you what properties are holding up well, where there are any concerns, etc. You can do this and monitor the results, therefore increasing your Oil Change Intervals.
Check out bobistheoilguy.com, some very interesting reading there on this age old debate. I recently read a post where a guy is using the Walmart brand SuperTech oil and getting results close to most name brand oils, conventional and synthetics.
It is of course a real personal type of thing. I grew up working on cars in the neighborhood with a local "elder" when I was in high school. He swore by Quaker State, so I in turn used Q.S. for years. As I grew older and eventually got access to this interweb thingy, I did a lot of research, usually while the wife was watching Idol or some other b.s. tv show. Quickly found out about Amsoil, etc.
I use synthetics my self, or synthetic blends. My last Ford recommended a synthetic blend in the owners manual. If you research it, test your used oil, and use what your preference and budget allow. It's your investment, protect it how you think is fit. Who am I to tell you what oil is right for you.
Most parts store labeled oil is good oil. Oreilly's uses Valvoline in many areas for instance, just bottled and priced as O'Reilly's. It's the same stuff in the bottle as the $1.50/qt higher valvoline.
These days the oils are all very good, conventional and synthetics.
Personally I like to protect my investments. I work hard for my money, and in my line of work, witness the affects of poor maintenance / hydraulic oil breakdown all the time. Heck, my John Deere lawn tractor has had Mobil 1 10W30 in it as soon as the manufacturer recommended "break in period" was thru. I change it every spring, and it looks as clean as the new stuff I am replacing it with. I don't think I would get that from any conventional oil.
No matter the performance of synthetics or conventional oils, I am still concerned in the performance of filters. I use Wix, or Napa Gold (produced by and same as Wix) always. If you have ever cut a few filters open you will see vast differences in the manufacturing qualities of the various brands. Wix is a very good filter hands down. Frams are crap.
If you had the best oil money and science could buy / manufacture, if your filter is crap, your engine is going to be in danger. I don't care what the properties of the oil is, if your filter cannot protect your engine from inherent dirt particles, your engine will be damaged.
Extended oil change intervals are great for those that choose to do so. I have the confidence in today's oils, just not so much in today's filters yet. I'm not saying you have to change it every 3,000 miles or else failure is eminent. I just feel that today's oils are more advanced and can last longer than the current filters and primarily today's engine's filtering systems. Today's filters will eventually go to bypass, once the filter media is completely full, then your oil is just traveling all through the engine unfiltered. Today's compact engine compartments allow for only screw on type filters, and as such, there is no good solution to this problem, other than going to a remote filtering, dry sump type system.
Sorry, that rambled on so long. I didn't intend for that.........
In the end, to each his own. I recommend testing used oil, and go from there. Don't cheap out on the filter!!!
First let me say that I have been in the oilfield business for years and have experience with synthetics as well as seen the engineering claims. Most are a bunch of poppycock just to sell the product and once the mind is convinced that synthetic is the cure all it is just about impossible to show a person other wise. That is not to say that synthetic oil is no good. It is if used where it is really needed. However Synthetic is mostly nothing but a hype when it comes to most conventional engines. Unless the engine oil is running above normal temps synthetic is a total waste of money. Now for those who swear by it in conventional engines by all means keep buying it, as it is your money to waste, but I challenge you to take two vehicles and treat them exactly the same and you will see that neither will do better then the other.
While there are claims that synthetic will get you extra miles there is not single study to prove it. No one has ever taken two identical vehicles and put them through exact normal driving one with synthetic and one with conventional oil and proven that synthetic makes the engine last longer. Keep in mind we are talking about the standard engines, not a NASCAR race engine or a dragster. Even the weekend hot rodder does not need synthetic as synthetic will only benefit the engine IF the engine oil is running too hot.
I have a ford truck that I have only used conventional oil in and I have over 400,000 miles on it and it does not use a drop between oil changes. I once had a motor cycle and used synthetic in it. I got about 75,000 mile on the engine. I put a new engine (not rebuilt) in it and went to conventional oil and went just as far on the second engine.
Also if you do the math synthetic costs more without any real benefit except that you can go longer between oil changes. So for 50% extra you can be hyped up and think you are doing something by using synthetic while the manufacture laughs all the way to the bank, but I suggest that you use conventional oil and change it as recommended. You will get the same benefits and have extra money in the bank.
One more thing. Some will try and tell you that synthetic is slipperier then conventional. That is more hype. The industry has standards and they are listed on the oil we buy as to how slippery it is. SM is the highest you can buy and conventional oils come in that grade. Here is a chart Motor Oil Grades and Service Ratings
Here is another article that gives some information. Car Bibles : The Engine Oil Bible
So if the manufacture calls for synthetic use it. If it is not exactly specified (required) then use the conventional and save a ton of money. You will get the same life out of your engine with conventional oil. Believe me IF synthetic oil was as good as some claim every manufacturer would require it for warranty purposes, but very few do. So unless you are building an extremely high performance off road vehicle use conventional oil.
Amen to that........ Father in law says same things, he was Chemical Engineer for EXXON. 20-30 years.
I use synthetic in my air cooled push mower but the 4Runner gets regular oil and a TOYOTA filter every 5000 miles.
I have seen guys like you. All mouth and no back bone. Here the deal. I will put up 10,000 dollars and you do the same both in one account. We will sign an agreement with witness'. We will change the oil on this truck together and then take a 5000 mile trip. We will then drain the oil. If it is 1 quart low after 5000 miles you get both mine and your 10,000. If not I get both. Now put up or shut up. By the way I am willing to bet you cannot reproduce the same results you boasted about on your other stats either but lets take care of this other first. Let's see who is slinging BS!
PM me a bank statement showing me you've got $10g to lose Junior, and don't try any funny ****. My father-in-law is the retired Senior VP of a major Bank chain here in the Midwest/South. So if you give me a certain bank you can bet your ass I'll have it checked out.
Hell, you should have to "Pay Up" if its a 1/4 cup low...you said it didn't use a drop......correct?
And just for the record.....I run an oil temp guage on my bike....so I CAN INDEED BACK UP what I'm claiming....
You'll give me the "I swear it never used a drop of oil, something must be wrong".
This was the last FORD I owned, a '91 GT 5-speed. I sold it in '99 with 42,000 original miles....and guess what, It used a quart every 3500 miles. So I guess I lied about the 5000 miles claim, it was 3500.
I owned both these at the same time, the other vehicle is an '87 IROC 350 which I ordered new as with the '91 GT. I sold the IROC in 2005 with 20,200 original miles. Both those cars netted me damn near $30g when SOLD. Although I had about $37g in them. I "might" be able to come up with 10.
Happy reading.
LOL Consumer reports is utterly worthless on things like this.
Number one they didn't even test a single full synthetic oil, and NO Mobil 1 is not fully synthetic it is a group III oil that is why at 7000 miles its pretty much had it.
What exact difference do you think there is going to be after just 60,000 miles while using a "Semi-Synthetic" Vs petroleum? They aren't all that much different.
That is one of the main gripes I have with Consumer Reports they only test a very select and small sampling of whatever it is they test.
That is why Sears Kenmore is always on top of the list with appliances even though Kenmore does not even make a single one, they are made by Whirlpool, LG, Samsung etc yet those companies that actually make the product miraculously never made the top of the list?
Not to mention there are numerous appliances they never test, like Gas Ranges for instance. The top one is of course a Kenmore for like $1800.
We bought a NXR gas range for $1800 which is WAYYYYYYY better than the Kenmore but if you go by CR you would never know that because they will never test a NXR range but the difference between the two is night & day.
There are at least 6-7 Ranges I can name off the top of my head that are far better but not according to CR because they don't even bother to test them.
Same goes for this bogus test which does not even use a single full synthetic oil.
Do a test like that changing the oil like it should be, 3000 miles for 1/2 the petroleum and 7-8000 using REAL synthetic oil and the other 1/2 of the petroleum oils and do it for 150,000 miles. THEN take those engines apart and see what it looks like.
All of the petroleum oils changed at 7000+ would be lucky to make it to 150K the other would be probably doing OK which basically shows that synthetic is at least 110% better oil than petroleum.
On some engines that run hot on the top end like my wifes Lexus ALL the petroleum oils would show signs of sludge more than likely no matter how often they are changed.
Amsoil, Redline, Royal Purple, are true Synthetics Group IV & V oils. I am sure there are a few others but cant think of them right now.
Here is a well-regarded post from BITOG that will serve to muddy the already turbid oil here:
Base oil quality is no longer defined by just three simple categories consisting of conventional, semi-synthetic, and synthetic. With the introduction of new processes and feed stocks over the past dozen years, we now have numerous base oils grades and blends thereof, resulting in a continuum of base oil quality, such as:
Grp I
Grp I & II blend
Grp I & III blend
Grp II
Grp II & III blend
Grp II+
Grp III
Grp III & IV blend
Grp III+
Grp III & IV & V blend
Grp III+ & IV & V blend
Grp IV & V blend
While the exact quality order of such base oil selections is debatable and dependent on component grade and ratios, the point is that the quality steps are now so small as to make labels such as semi-synthetic and synthetic difficult if not impossible to place. The industry chose to draw a line between Grp II and Grp III in defining “synthetic”, but the difference is merely a single VI point, and therefore meaningless from a performance standpoint.
Certainly there is a meaningful difference between the low end and high end of the spectrum, such as Grp I vs a Grp IV/V blend, but the difference between adjacent levels, and really even levels that are three, four, or five apart, is easily blurred by the additive system.
Hence, the great debate over “synthetic” versus “true synthetic” is dead. The use of the word synthetic today only signifies that the base oil blend leans toward the higher end of quality continuum, and translating that further into finished oil performance becomes a stretch.
Unless you have a special engine or driving conditions, you are better served concentrating on specifications and approvals rather than base oils for estimating oil performance.
true synthetic oil - Bob Is The Oil Guy
I use synthetics but not because I believe they make the engine last longer nesessarily. I believe the oils number one job is to keep metal to metal contact from happening. If conventional oils did not achieve that engines would fail due to oil all the time.
I do believe synthetics perform higher and are possibly overkill but... I did like this quote from Singtoe's link to Consumer Reports:
"One distinction: According to the laboratory tests, Mobil 1 and Pennzoil Performax synthetics flow exceptionally easily at low temperatures - a condition our taxi tests didn't simulate effectively. They also had the highest viscosity under high-temperature, high-stress conditions, when a thick oil protects the engine. Thus, these oils may be a good choice for hard driving in extreme temperatures."
So in cold or hot climates (or slow going off roading in hot weather) synthetics may have a noticeable advantage.
I think the CR article was put out long before extended performance oils were on the market but they still tested Mobil 1 in some of the cabs to 12000 miles and found (with the one engine that didn't have other issues) that there was no difference between the 12k engine and 6k engines.
I personally choose to use synthetics that are extended performance for the additives. It's the additives that allow more miles not the fact that it's synthetic.
Since I only change my oil once per year on my vehicles I save money over conventional oil. I can get 5 quarts and a filter for about $32-38 on sale. On my 4runner I also use the bigger size Mobil 1 M1-209 filter and it takes about 7 quarts to put it just above the fill line so I'm getting more oil in there as well.
If they made an extended performance conventional oil that was half the price of Mobil 1EP, Castrol Edge or Pennzoil Ultra I'd buy it but I haven't seen that on the shelves.
I would be as stupid as you to give you my account numbers. I will PM you with my phone numer and we will set up an account with a private party. We will both sign a contract to put the money in by a certain date or forfit a 500.00 dollar earnest money.
I have now sent the PM with contact information.
You can "black out" account numbers....:bash:
and pm sent back
I'm headed to Key West on 6/4 for a couple of weeks, for a small vacation with family & friends. I will contact you upon my return to Ohio.
Okay, here's my situation.
I don't do a lot of driving. 90% of all driving I do is quick start and stop trips in very hot and humid conditions. I've been going to the dealership to get my oil changed. They use Valvoline bulk. And they recommend every 5000 miles, which I've been doing now for quite some time. My 3G4R has 100,4XX on it. It runs pretty well. No problems.
My question is should change to synethic or keep doing what I've been doing?
You should research on your own and come to your conclusion. Some people will say switch to synthetic, some will say stick with conventional.
It is the same as tires, if you ask that question, people will push their opinions and sway one way or another.
seltzernator
