Saved
First let me say that I have been in the oilfield business for years and have experience with synthetics as well as seen the engineering claims. Most are a bunch of poppycock just to sell the product and once the mind is convinced that synthetic is the cure all it is just about impossible to show a person other wise. That is not to say that synthetic oil is no good. It is if used where it is really needed. However Synthetic is mostly nothing but a hype when it comes to most conventional engines. Unless the engine oil is running above normal temps synthetic is a total waste of money. Now for those who swear by it in conventional engines by all means keep buying it, as it is your money to waste, but I challenge you to take two vehicles and treat them exactly the same and you will see that neither will do better then the other.
While there are claims that synthetic will get you extra miles there is not single study to prove it. No one has ever taken two identical vehicles and put them through exact normal driving one with synthetic and one with conventional oil and proven that synthetic makes the engine last longer. Keep in mind we are talking about the standard engines, not a NASCAR race engine or a dragster. Even the weekend hot rodder does not need synthetic as synthetic will only benefit the engine IF the engine oil is running too hot.
I have a ford truck that I have only used conventional oil in and I have over 400,000 miles on it and it does not use a drop between oil changes. I once had a motor cycle and used synthetic in it. I got about 75,000 mile on the engine. I put a new engine (not rebuilt) in it and went to conventional oil and went just as far on the second engine.
Also if you do the math synthetic costs more without any real benefit except that you can go longer between oil changes. So for 50% extra you can be hyped up and think you are doing something by using synthetic while the manufacture laughs all the way to the bank, but I suggest that you use conventional oil and change it as recommended. You will get the same benefits and have extra money in the bank.
One more thing. Some will try and tell you that synthetic is slipperier then conventional. That is more hype. The industry has standards and they are listed on the oil we buy as to how slippery it is. SM is the highest you can buy and conventional oils come in that grade. Here is a chart Motor Oil Grades and Service Ratings
Here is another article that gives some information. Car Bibles : The Engine Oil Bible
So if the manufacture calls for synthetic use it. If it is not exactly specified (required) then use the conventional and save a ton of money. You will get the same life out of your engine with conventional oil. Believe me IF synthetic oil was as good as some claim every manufacturer would require it for warranty purposes, but very few do. So unless you are building an extremely high performance off road vehicle use conventional oil.
