System finished...
91bulldog
Wow, your really fixing that thing up. First off I like the bar you put the front grill.
It looks like your subwoofer has a amp attached to it. Is your subwoofer removable, in case you need to haul some stuff?
Anyone seen a double-sized aftermarket Radio? I'm really interested in upgrading my audio system and I'd like to fill up the whole space. Also who did you turn to for the parts? I tried BestBuy and they don't have any kits for '03s yet.
Looks Good. Did you also replace the door panel speakers? If so what kits did you use? I am looking at replacing mine.
YES... I REPLACED THE DOOR SPEAKERS TOO. I DID NOT USES ANY KIT FOR THE DOORS. I USED THE BASE OF THE FACTORY SPEAKERS TO MAKE IT FIT PERFECT. I USED A DREMEL TO CUT THE BASE.
nice setup, is that a 10 or 12 type r in the box? how does it sound and how many watts and amp are you puching to it?
Any issues with radio reception? After replacing my radio, I am getting weak station signals. When I connected the radio I only used the regular sized antenna cable. I did not know if i needed a adapter for the antenna, much less which to get.
12" type R woofer= i think the rms is 350watt and max is 1000 watt. I'm using the rockford 500a2 to power the woofer. Amp is perfect for that woofer.
i only used the regular size antenna calbe too. my stations FM and AM stations are fine...
How clean is the install?
The first photo is kinda dark.
Does it look stock?
Can we get a brighter photo if possible?
Thanks,
Did you use factory wires? What speakers/tweeters did you use up front? What rear speaker did you use? (Brand/Model?)
for the fronts= Alpine SPR-694A 6x9 and factory tweeters
for the rears= Alpine SPR-174A 6.5
for the woofer= Alpine SWR-1241D 12in
