T-Tech shop in the Phoenix area?
Phx994Runner
Does anyone know of, or better yet can recommend, a shop in the Phoenix area (preferably north Phoenix) that uses the T-Tech transmission fluid exchange system?
Thanks!
I wouldn't waste my money. The t-tech machine uses a pump to force fluid through, which I am not a fan of. The dealership where I work uses a machine that lets the transmission pump do the work. You just fill up one part of the machine with the new fluid, then hook up the machine. Turn on the truck, it pumps the old fluid out and the new fluid is sucked in. This way there is no chance of damaging the torque converter or solenoids.
t-tech info...
I don't think that's the case - from a multitude of threads here and on the IH8MUD forums the t-tech is the safest and best way to go.
From the company's website at:
https://clore.zendesk.com/entries/225629-frequently-asked-questions-t-tech-transmission-fluid-exchange
Q: What makes a T-TECH ATF exchange different from other mechanical ATF exchanges?
A: The T-TECH exchange is powered solely by the vehicle’s transmission pump. This means that the T-TECH exchange occurs at the transmission’s operating pressure and will not over-pressure the vehicle’s system, which could result in damage to system components. In addition, you will get a 100% proportional exchange every time, as the used fluid pushes new fluid into the vehicle’s system. The simplicity of the T-TECH system, with its patented auto-alignment, auto-bypass and visual advantage features, also means that every member of the shop team can perform a successful T-TECH service, quickly and efficiently.
Forgot to ask in prior post, what specific machine is that at your dealership? If I find a dealership or garage with that other machine line then that should be good, too!
Thanks.
