T4R not working on Tapatalk
octanejunkie
Elite Member
Issue seemed to occur right after the forum was down a few weeks ago. The issue "forums load then disappear in Tapatalk" is well documented on the internet and seems to be resolved by forum admins.
Just me?
Mine is working fine except with this evening. I could not get on here but I could login to my CTS-V forum. Kept saying incorrect password but I know it was right. Logged on thru safari no problem. Just kept trying and restarting and finally got on with face ID. Not sure if it was tapatalk on my iPhone.
Just me?
Check out the other thread on this created last month. I've had luck going into the phone settings, to storage, then to clearing the Tapatalk cache. After that re-opening the app it should work until ... who knows when. If I open Tapatalk and want to get on the forums here every few days, I just clear my cache before I open anything.
Not ideal, but it does the job until the plugin gets updated! :cheers:
Done and done!
Update: clearing cache each time is a PITA
I've been having problems for weeks. All other forums work on Tapatalk, only t4r is affected. I can occasionally get on but doesn't work most of the time. Tried logging out, uninstall etc ugh...
Happened again to me the other day. I don't think I can just clear the cache from an iPhone, or at least I don't know how. It only happens with this forum but my others still work fine. I ended up having to delete the app and reinstall, after that it worked fine. Only takes a few minutes but still a PITA.
It's been happening to me since the site hack/upgrade. I have to unfollow the forum and then re-follow and log in. It will work as long as the app stays open but as soon as the app closes I have to start the process all over again.
I've been having this issue as well. If you cannot access the forum or pages are blank, back out to the base app where you go to enter forums and log out of the actual tappatalk app. Once you log back in, it's good! Been working for me but still a pita
Sent from my SM-N950U using Tapatalk
I’ve never had problems reading this forum on Tapatalk, my issue is nothing from this forum shows up in my feed or notifications, including threads I’ve subscribed to, replied to, or was the OP. Anybody else or is there a fix?
*update* I joined another forum and since then I can close and open the app without having to unfollow / follow.
I think we are in the clear now- it seems the tapatalk issue has been resolved with the site update wrapped up and everything squared away in the app. Everything is working for me now again! :cheers:
I haven't been using Tapatalk much because of the issue, and is late as last week I believe it still wasn't working properly, but today it did
Hopefully we are past all that ugliness now
Sent from my Pixel XL using Tapatalk
