taco 5100 and eibach coils
spenedwrds
I have a set of tacoma 5100 and a set of toytec/eibach coils. And pairing them with a set of 8 wraps which will give me about 4 inches of lift. I was wandering what setting to put my 5100 on to level the truck as much as possible?? Mine is a 2wd :(. Is there anyway I can get close to 4 inch in the front since I don't have CVs?
thanks!
The 112-620 coils?
You are going to want to set the c-clip on the bottom setting. If you put it on any of the other settings you will get too much lift. The springs are designed to give 3" of lift by themselves. If you pre-load them on one of the higher settings you'll get a lot more lift and run into problems with your cv's, ball joints, etc.
You could be a guinea pig and try it on the 2nd setting. I'm willing to bet it rides super stiff and will give you problems.
It could potentially hurt your ball joints. Also, if it gives you too much lift your shock could be fully extended all the time which will not only ride like crap, but could damage the shock.
I don't think anyone has tried it on the 2nd setting. I know that on the 2nd setting it will lift the 4th gens 3". But they are a bit heavier.
Like I said, you could be a guinea pig if you want to try it out.
I would suggest going with top plate spacers instead though. Good luck! Be sure to post what you end up doing.
will do!! my eibach coils should be here late next week. oh and one more question. i know i dont need the diff drop. what about a adj panhard? should i get one? or is it not needed?
Thundro
