Tail light housing removal
Two nuts need to be removed from inside the little panels behind them. They're a little difficult to get at but it can be done.
There's probably some pictures on the forum if you use the search.
Also, once you have the nuts off, the housing can still be stuck a bit (foam seal/gasket). I've found that pushing outwards on the housing bolts themselves helps to loosen it up.
youngrk
