Taking the doors off of my SR5 86
mikekaduce
Love the look with the top off, and wanted to take a step further by removing the doors. Will having power everything with my SR5 model complicate this, or is everything pretty quick-disconnect?
It depends on the disconects at the door. Open the door and look in the jam and see if there are disconects. I have taken mine off quite a few times, but since I have no power options, it is just 4 bolts and a pin per door. Good luck, Sam.
Take em off, it's a lot cooler!!
yeha, i have an '87 that is not an sr5, so i only have the 4 bolts and a pin, if you don't have any sort of quick disconnects in the door jamb, which you probably don't, unless a previous owner set it up, then you should definitely hook some up. I take my doors off all summer, and anytime i am off on trails. It's freakin' awesome!!! good luck!
