off-road runner
Now that the snow is flying and roads are all wet I've noticed the front brakes squeaking loud on a TE with ~ 4,000 miles. This isn't the squeak inside the cabin from the brake pedal like others have complained about, this is definetally from the calipers and only squeaks and squeals when brakes are applied. This has led me to take a quick look at the rotors thru the rims. I noticed speckled surface rust on the front/outer/driver side rotor that easily rubs off with my finger, leading me to believe the brake pad is not making contact with the rotor at all on the outer side making that brake VERY ineffective. Probably just a stuck piston in the caliper. I didn't crawl under to check if that inner side of the rotor is contacting the pad because Im a little lazy and didn't pay $35K+ to roll on the ground under the truck. It's going back to the dealer tomorrow so they can check it out. This problem must not be common or there would have been other threads about it. I hope I did not get a lemon.
