TE Under Slide-out Storage.
TOY2G
Getting ready to leave for Colorado, and I found myself lacking enough room for all 4 of us, our personal gear, and tools.... So I was removing the flip down wall on my slide out, and I realized there was room under it to store some of the stuff. So between the storage compartments, and the new found room under the slide out, I was able to do away with one entire ARB large recovery bag.
d1a312f4c9767fbe780a25f62b92d8e7_zps236c10f3.jpg~original
For the record it was able to fit the following under there
First aid kit
Snatch block Lrg
Snatch block sml
Shackle
Air hoes extension
Air inflation hose/gauge
Sherpa solar charging system
SOG tomahawk
SOG field knife
30' bungee cord
Waterproof field dressing x 8
Emergency blanket
And in the skinny storage between the slide out and the seat:
Gorilla tape
Wet weather gear
Solar shower
TeraLUX flashlight
Insect/snake bite kit
Matches
Gerber multi tool
Factor 55 hitch recovery mount
Rubber coated twist ties multiple sizes
Another 30' bungee cord
SOG survival knife
Waterproof matches
6 assorted chem lights
And in my single side compartment:
Winch controller
Factory jack
First aid kit
SOG multi tool
Anyway, like in said, between all this stuff and the stuff I crammed into my other Large ARB bag, I save a good chunk of room.
I'm one of those people who try to bring everything I may need, and then some.
Nice! :) Where are your Israeli bandages and quick clot? :D
That's the first thing I noticed when I slid that thing out, I wondered why didn't they craft a nice little storage spot there, a better one anyway. That trim seems like a good 2+ inches above the actual floor enough to equate to real capacity. Slim tool box, straps, tire irons, shackles and blocks, hoses/belts, all that good stuff.
Excellent! I had been eyeing that space up & wondering if it would interfere with the slide. Great use of space.
You have 1 7/8 inch to fit stuff I there and not affect the operation of the slide. Since my spare tire is in the back, I wonder if I should work out some sort of drop in storage boxes the go through the floor..... Pretty sure I'm going to try this one.
Toy2g,
I use the area under my slide out tray just like you do. I've been thinking of trying some kind of way to cut the floor and add a storage box or make a deeper storage compartment. If you find a way let me know. By the way, I'm heading to Colorado in the beginning of August and the first week of September. I have a vacation home in Pagosa Springs and go off roading in the Silverton/Ouray area. If you are going that way give me a shout. Maybe we can hookup. My e-mail is [email protected].
Joel Hebert
Brusly, La
Toy2g,
Joel Hebert
Brusly, La
Josh, I will add you to my contacts, I will be in Telluride and Ouray from the 9th to the 26th.
I will post a write up when I cut my flow (if I do). I think I can drop in two trays that go roughly 9" into the floor with lids.
I am definitely not that adventurous at this point in time but do keep us in the loop if you do decide to cut in some rear floor storage!
First aid kit
Snatch block Lrg
Snatch block sml
Shackle
Air hoes extension
SOG tomahawk
SOG field knife
30' bungee cord
Emergency blanket
Gorilla tape
Wet weather gear
Solar shower
TeraLUX flashlight
Matches
Gerber multi tool
SOG survival knife
Waterproof matches
Winch controller
Factory jack
First aid kit
SOG multi tool
Did you remove anything under the sliding tray to make room for all these things or is this the standard amount of space that is under those sliding trays? I'm curious to install one or make one of my own.
Oh got it, so how deep is it? I don't have one so I am wondering if it's worth installing one to have the slide out and the storage.
Its exactly 2.6 inches deep at its deepest under the tray, but as you can see that deep enough for many things. The storage box behind the tray is about 5 inches deep.
