What would cause the temeperature to rise while i am going up hills on the highway or sometimes while i am in idle at a stop light?? After i get back going on steady ground the temperature goes back to normal.???
Have you checked your fluid levels? You may just be low on coolant. I would also check the oil level as well. If those are good, assuming your fan is spinning, then I would start with the t-stat.
