i bought my truck about 2 months ago and have had nothing but problems from the brakes. i've had the high hard brake pedal that many complain about. i tried replacing the check valve, and i tried the test in the fsm regarding the brake booster. on top of that my rear brakes don't seem to work. they work well enough to stop rotation when on jack stands, but hard braking on ice (i have the abs fuse removed) won't lock up the rear wheels. i thought i had bad axle seals leaking into my drums but it turned out to be a bad wheel cylinder(pads and shoes now replaced). i'm supposed to get access to a vacuum tester tonight but i don't know how many inches of merc, or where to hook it up. anybody out there that can help? anything else i should be checking? also i have bled 2qts of new fluid thru it but i've never had any experience with abs systems before.
