That plastic thing near the shifter
Streethound
I was cleaning out my 03' 4runner yesterday when my shop vac sucked up the tiny plastic cover that is right next to the shifter. I sifted through a pile of crap in the shop vac but could not find the part.
Anyone know where I can find a replacement? Its a tiny silver colored plastic piece that covers what appears to be some sort of connector.
Any ideas?
If you dont have a conscience, prob not spelled right, you can always steal another one off a stealership vehicle. Otherwise the parts dept should be able to get you a new one. :bigok:
4runr30 said:
... the parts dept should be able to get you a new one. :bigok:
That's the cover for the shift lock reset. IIRC someone previously posted about spending $$$ at the stealership to replace such a small part. I would search real good through the shop vac.
Any ideas?
It sounds like you lost the cover to the emergency shifter unlock port. I would try the dealer and see if they sell it separately. Did you look through the folds of the shop vac filter? It might be trapped in there.
I spent 30 minutes combing through the shop vac and couldn't find it anywhere.
I did find a ton of other nameless junk though!
Man, I hate paying the dealers for parts. I recently had to replace the Parking Brake Shoe Spring Hold Down. They charged me $20 for a spring, a couple of washers and a pin.
Could have ordered the entire brake hardware kit for $15.
Thanks guys for the suggestions. Maybe I'll pay a visit to the used 4runner lot one of these days...
Thanks for the link CJ3Flyr - its really hard to tell which part it is from the break-out but the site is fantastic!
I'm going to hunt through the garbage again and see if I can locate the silly thing.
I got one from my stealership. It was under $5. They had to order it, but it only took a couple days.
Any ideas?
Sounds like it's time for you to take a little test drive!
The particular runner that I purchased didn't have that part for some reason so the salesman just took one off of another runner.
Junk Yard FTW!!!! probably won't even charge you. you could just slide it in your pocket and said you didn't find anything. Way too easy
patnewton
