The CatLock 1.0: Protecting Catalytic Converter
MuddyWater
The CatLock 1.0: Catalytic Converter Protection!
Hello 4RNRS (3G)!
Well, paranoia finally got the best of me. The fact that I visit NorCal (most reported incidents of Cat theft next to Boston and Detroit) from time to time and because I heard last year in SoCal there WAS a big issue with it, I decided to get something to give me some piece of mind. I decided to fork over a $100 to purchase "The Catlock 1.0". I figured what's the use of spending more on the deluxe models and figured this would provide enough of a deterrent without breaking the bank. The CatLock took me about 30-45 mins to install. The longest part was tightening the 4 large breakaway bolts that hold the clamp to the cat. The second longest was threading the cable through the frame (IN/OUT) and over. I also grabbed my bolt cutter to cut off the excess thread. After all was said and done, I'm glad I purchased it. The cable itself was thicker than I anticipated, much thicker than what appears in the product picture. Also, I was concerned about the amount of tension the breakaway nuts would apply to the clamp. In the tutorial video found on YouTube, it appears they breakaway easily and was concerned that not enough tension would be applied to secure the clamp firmly in place, but fortunately that was not the case. In fact, it applied so much tension that I was worried it was going to damage my cat, but luckily it was just enough. The installation was pretty straight forward, so I didn't feel the need to do an official tutorial. By looking at the pics you can get an idea as to how I installed it. I initially was going to use the cross member located directly below the cat but was concerned that something may get caught/hooked on to the cable. Also if someone were equipped with a cable cutter, they would need to do so in an upright position thus putting the in plain site. Lastly, do to the taughtness/rigidity of the thick cable, the actual cables are pressed up against the bottom of the vehicle and do not touch the lines you see in the pictures below. Also, unlike what was instructed in the installation pamphlet, I mounted the cables diagonally from each other versus directly next to the other.
Hope this provides those of you who are paranoid about cat theft and gives you an idea about this specific product. However, keep in mind that if a thief wants something bad enough, they WILL get it, but based on the laxed attitude of my neighbors that most likely do not having any protection.., well that and the pending holidays (Desperate times call for desperate measures), I will hopefully be the last one they target.
Take care and keep 4RUNNIN!
I'm with you on the paranoia thing. I park mine outside on the driveway. Every week the salvage guys drive around our area on garbage day looking for scrap metal. the cat is worth a little more than rusty steel bits in the trash. Mine has the cat clamp but anything to slow them down is beneficial.
Maybe I am insane, but if they have a reciprocating saw to cut through the exhaust pipe that cable won't be much of a hindrance
The CatClamp, that's the really nice... or should I say SECURE model. A funnel web of cable that one is. Yup, I've read/heard of too many people who decide to invest in a anti-theft cat device after the fact and as I mentioned the holidays are right around the corner. So, theives will be looking for that ez money and targeting those unfortunate enough who have parked away from the lights and cams of the holidays. It's comforting knowing at least there is something there, especailly after personally installing it and knowing how secure it is. Funny you mentioned the metal scavengers (salvage guys). One past by as I was coming back out to finish my install. Couldn't help but glance over my garage to make sure all my precious metals were still their (tools, jacks, LittleGiant, etc). By the way, like the avatar. I personally would substitute the coffee for scotch but of course wouldn't enjoy the two together. Take care!
Nope not insane, but during the video tutorial created by CatLock. They demonstrate and attempt to cut through the cable with a recip without success. However, cable cutters or even a bolt cutter, that's different. If anything its a deterrent and at least the manufacturer will refund you the cost of the CatLock... "if your properly installed CatLock fails to prevent your automobiles's catalytic converter from theft". Need to keep reciept with order number, vehicle profile, and police report. Now, their definition of "...properly installed" could be their out. If my RNR is targeted, I'm just hoping for the lazy thief not the seasoned pro.
Update
After driving a day after the install, I encountered a vibration noise while in gear and at idle/stop. Discovered it was a portion of the cable transferring the vibrations from the engine/exhaust to the body. To remedy it, I looked to see for an indicator where the vibration may have rubbed off paint/coating and then simply split a left over piece of hi-temp tranny hose from my trans cooler project and wrapped it around the portion of cable that was in contact with the body, creating an insulation between the two contact points. Vibration silenced.
Free advice. Do that where ever the cable touches something. The Stainless steel cable will act like a saw blade and cut through even the frame of the truck over time.
Thanks for the advise and unfortunately, I spoke too soon. The vibration is somewhat still there. So as soon as its cool, I am going to insulate all contact points between cable and vehicle. It's good using left over parts from other jobs; maximizes intital investment. Thanks again!
Fixed the vibration. It was being generated by the passenger side CatLock cable. Simply had to just move it around to where it was nolonger touching the lower body. Now, I'm good to go with piece of mind and no annoying vibration to remind me its there.
Forgive me...I live in the sticks. What's a cat worth as scrap or whatever to prompt people to steal them. Sounds like a real issue some places.
It's a crime in my area that has fortunately dropped considerably, but is more frequent in northern California, Boston, and Detroit. What theives are seeking is the highly valued metals contained in the factory cats such as platinum, palladium and rhodium. I refer to them as "factory" because aftermarket cats do not contain (or have very little) such metals versus the factory cats which in turn reflects as to why factory resplacement are extremely expensive. Typically theives can expect to get $100 to $150 for a factory cat and target high profile vehicles due to accessibility.
Depending on the model and make of the vehicle and without some form of deterent, a catalytic converter can be removed in a very short period of time. It is not something you immediately notice missing until you start your vehicle and notice a very loud exhaust noise due to the exhaust no longer going through your muffler. A new catalytic converter may cost between $400 and $1,500 and the cost to repair the vehicle could be between $1,000 and $3,000.
To prevent such a crime from happening to you, it is recommended that you try to park in a safe and secure place, where a stranger underneath your vehicle would be instantly suspicious. If possible, keep your car in your garage instead of on your driveway or in the street. If you have a car alarm, a competent installer can install an additional sensor on the converter to set off your alarm when the thieves attempt to steal it. Most automotive repair shops or muffler shops can tack weld the nut and bolt which should prevent most thieves from easily unbolting the assembly. Additionally, you can engrave some sort of unique ID number (NOT your SSN) on your converter. Having this information engraved on your converter would assist in returning the converter to you if it is somehow miraculously recovered, and will also assist in the prosecution of the cat burglar... sorry, couldn't resist.
Hope this sheds some light.
:biggrin2:
Happy Holidays!
Thanks for the explanation. I guess desperate times call for desperate measures.
I live in a very low population density area so if I spot someone is under my truck, I'll probably know him.
Funny story... also true !
A buddy was travelling through Newfoundland (work related) in a government vehicle when the hanger bracket let go and let the muffler dropped to the ground.
Rather than walk or just drag the muffler to the nearest repair shop, he went to a nearby fence and snipped of a length of wire to fasten the muffler back up so he could travel.
While laying under the car wiring up the muffler, he heard another vehicle pull up and someone got out and said
"Wach-ya do'in 'by"
to which my buddy replied
"I'm just trying to get this muffler"
To which the Newf replied
"OK...you gots the muffler by, I'm gonna gets the battery"
Tx470
