The Josh's Build Thread
Getting ready for shaver lake so i went on some of the trails in my backyard.
i think i need to replace my Light Racing balljoints, the front end feels a bit sloppy, i think ill put the wheels and further inspect, i also am leaking a bit of diff fluid from my rear axle seals, i called currie and they said to check the fluid level as it may be too full and adjust as neccessary (thought it was weird to leak on a 2 year old axle)
First, your truck looks amazing. After the mention of THN I remembered your episode.
Question: What trailer tent do you have? Is it ARB, couldn't quite tell from photos. Also did you make your trailer or purchase it. Again, the build looks great. thanks
josh
4Runner Hot Water On Board
engine bay
file-849.jpg~original
heat exchanger
file-1551.jpg~original
water fill port
file-1897.jpg~original
file-1917.jpg~original
pumps off
file-955.jpg~original
pumps on
file-300.jpg~original
shower hookup
file-2139.jpg~original
file-1833.jpg~original
hot water
file-1978.jpg~original
undercarriage
file-525.jpg~original
heat exchanger pump
file-556.jpg~original
particle strainer
file-1148.jpg~original
shower pump
file-2129.jpg~original
from left to right (outlet for heat exchanger, outlet for shower, inlet from heat exchanger)
file-549.jpg~original
pump
file-1943.jpg~original
file-1544.jpg~original
Hi,
You have done a great job in your 4Runner. I am the 5th Gen runner owner and planning to build a Hot Water On Board System using heat exchanger.
I would like to seek your advice:
1. To re-divert the coolant to the heat exchanger, will it cause any potential risk (e.g. mechanical failure, fire, pressure or coolant lost)?
2. How are you going to deal with the setup in winter time or in any icy place. The heat exchanger and pump, also your water tank, would they be damaged ?
3. It looks like there is no 5th Gen 4runner owner do this similar setup. Do you any ideas why?
4. Looks like you are expert in doing huge modifications on vehicles. I am a non tech guys, do you suggest that this modification to the 5th Gen 4runner is feasible and safe for durability of the vehicle?
Thanks to give ideas !
Tap in the heater core hose (coolant flow direction)
engine bay
heat exchanger
water fill port
pumps off
pumps on
shower hookup
hot water
undercarriage
heat exchanger pump
particle strainer
shower pump
pump
:israel:Hi,
I am the 5th Gen 4Runner and now building the same kind of on board hot shower.
Where did you tap in the heat exchanger to the existing heater core hose?
Did you tap in the heater core hose (coolant goes into the heater core) or the return path (coolant flow out from heater core) ?
Do you have upper and lower pipe to carry coolant into the heater core?
I enclosed my 5th Gen 4runner picture for easy of illustration.
HI josh those fender are really sick i am wondering what are those fender are they tacoma fender that you put on those thank !
Its been awhile guys, but have some new things planned for the rig, here is a picture i took yesterday of the new rack i built to hold the RTT
Staying in shaver lake for the week and today did a run up to bald mountain and then to strawberry lake
Sent from my SM-N986U using Tapatalk
Glad to see this thing still going! Your truck has been one of the inspiration builds for my own.
Thank you so much man, yeah ive been quiet for a bit but im working on getting back active here with some changes and updates, Just rolled over to 201k miles and coming soon ill be doing Total Chaos Long Travel 3.5. Shocks have been on order since February.
Awesome pictures! Is that a drone shot or did you climb up a tower or cliff or something?
Sent from my KB2007 using Tapatalk
tuṣṭāva
