The LFD Off Road Thread
Can anyone confirm whether or not a Yakima Skybox or Showcase rooftop cargo box would be able to clamp onto the LFD crossbars? I ordered and received a 7/8 roof rack that's still in a pile of parts to be installed when I get back.
I'm prepping for a duty station change and will be driving from Virginia to California once I'm back from deployment.
Any help is greatly appreciated! Thanks!
Can confirm. I have about 500 miles on a Skybox 16 with LFD crossbars.
EZ-PZ
EZ-PZ
Seconded. I have this exact same setup. You have to slide everything in the most forward postion, and it gives you about an inch to spare at the back for hatch clearance.
I was initially hoping to run 1 bar with the fairing, then the two to carry the box, but didnt work out for me. I'll have to take the fairing on and off with I run the Skybox.
EZ-PZ
Thanks!!! I was really worried that the mounting hook wouldn't be able to get a good hold of the LFD crossbars since its squared and big.
Would you happen to have any pictures or can you snap a picture of it mounted/clamped on?
Couple more prototype things coming through production this week!
We just got our first bed racks for Tundras and Tacomas through this week (probably doesn't interest most of you guys though). They utilize the standard crossbars as part of the design.
We also came up with a wide crossbar to go with the bed racks, since a common use is mounting Rotopax on the sides of bed racks. The new wide crossbar will allow a Rotopax mount to be bolted directly to the crossbar without any additional mounting plates.
Being that its a standard length crossbar, these will also work with our 5th Gen roof racks! It'll make a nice mounting option.
Compared to a standard crossbar
Might be too soon to ask, but any plans for an aluminum version of the wide crossbars in the next few months?
Stainless steel, yes. I don't think we'll offer these in aluminum though. Aluminum has a decent amount of flex, and I can see people using these wider ones with heavier concentrated loads. The stainless will give the rust resistance while maintaining the steel strength.
That's great, looking forward to it!
just wanted to drop back in to say we've had great success with our LFD bar x wind fairing combo when i comes to being able to utilize our Thule Sonic XL cargo box. put a ton of miles on this over Christmas and both the wind and gas mileage penalty was negligible at best. these bars provide plenty of room for the Thule "feet" to hook around and under.
here's a side shot to better see how they're arranged. just sitting up there they make no noise with the fairing. i found that with the fairing adjusted to its furthest clearance outward from its mounts, the wind was buffeting it hard enough that it was tapping the roof at highway speeds. adjusting it to the closest distance to the bar solved that. not a problem with the design - just the characteristics of the air movement where my crossbar is mounted. if the crossbar was in a different place, it probably would have acted differently. nice to have the adjustability though, for any situation.
the only "repair" i've had to make is add a little touchup paint to one area right around a t-nut. i didn't initially tighten it enough, and then i retorqued it down hard in cold weather and i think i cracked the powdercoat a bit so there's a small spot of rust. nothing major. still a solid product.
