I see your nail through finger and raise you an angle grinder across back of finger.
For those that don't know [MENTION=135317]rkntoy[/MENTION] put a nail through his finger just before starting his dual case install. Not one to be out done I decided to loose control of my angle grinder. It then proceeded to hit my left middle finger at about 3000 RPM's. Guess what I was supposed to start Monday? Yep, my dual cases. I'm not sure if it's irony or just frikkin sad but it happened to both of us. lol
The sum total of damage was pretty good. At first I just kept on working figuring it was nothing. About 2 minutes later I realized my glove was soaking wet and there was a ton of blood going down my arm. FML. Guess I'll have to stop work and take a look.
I grab one of our apprentices and tell him to get garden hose hooked up. I grab the jobsite first aid kit(thanks OSHA!) and meet him it the hose. After taking off the glove it's just gushing. I let it gush to flush out what the grinder left in there. After a minute I clean it off with the hose and compress it. 5 minutes of compression later I release the compression.
Normally 5 minutes of compression is long enough to stop the bleeding enough to be able to get a quick look at the real damage. Not this time. It was still flowing like a faucet. FML. There's another little trick that works well to stop bleeding. I grabbed a latex glove and slid my middle finger into it. Then I cut off the tip of the glove. Then I slowly rolled the glove all the way down past the cut. Bam. Instant tourniquet.
With the blood finally stopped I was able to take a closer look. I cleaned it up and did a few range of motion tests. Damn it. I hit the tendon. I could see it moving and there was noticeable damage to it. The good news was that my finger was moving with it so it was not severed.
I released the tourniquet and snapped a quick photo for you guys then headed off to the ER. The ER doc did the exact same tourniquet technique and also the same range of motion testing. He was nice enough to give me a huge dose of Lidocaine first though. After a thorough cleaning I got a few x-rays to make sure no metal was still in the wound. After that another cleaning then some stitches and a finger splint.
He estimates I went through about 30% of the tendon. I have an ortho appointment Monday to figure out how long I'll be splinted and when I can resume normal life.
So my duals are on hold. lol
