Things to check after battery replacement
tgc08t4r
Just a heads-up that after you replace your battery it will be necessary to re-initialize your driver's side window, moonroof and rear window "auto-up/down" feature using the instructions found elsewhere on this forum. I mention this because after battery replacement my rear wiper/washer would not work and I proceeded to check the fuses and then disassemble the rear hatch cover to check all the electrical connections, which of course were all fine. It then dawned on me to check this forum and found the answer quickly and after re-initializing the rear window everything worked as before. Except now I have that black sticky crap they use to stick the rear hatch vapor barrier on all over my hands. Should have checked the forum first, as always!
Is that stickey stuff really a vapor barrier? Maybe I should have paid more attention when I "restuck it" after my backup camera install?
It's what they use to hold the clear plastic sheeting in place. It's intended purpose is for dust and moisture control.
DionicioLives
