Thinking of upgrading from a 99 SR5 to a 01 SR5..
birchy
Just wondering if there's any major differences I should take into consideration.
I understand 2001 was the first year they introduced the traction control system? I can't find that guys website that lists all the changes by year...
What kind of implications does this have for off-roading? I don't do anything major.. just a fly fisherman.. so some back roads I take can be pretty knarley. But I never do any crazy rock climbing or mud bogging or anything..
Do you have a rear locker on the '99? If you don't then their really won't be any big diff but your '99 does sit about an inch higher but if you are just taking rough roads and not much else there really won't be any diffs.
I wish I had the rear locker.. but no.
I did a quick google search and some person made this comment about the traction control:
"The benefits of a 01-02 are:
1) AWD system. Allows you to engage 4WD on dry pavement, unlike 96-00 (Except 99-00 Limited).
2) VSC system. (traction control). I installed a switch that turns this off. If you're in mud, snow, this system will not allow you to power your way through--it just cuts out power to "help" you avoid sliding. Install of the switch is simple, and the payoff (i.e. parking lot drift sessions) are well worth it.
3) TRAC system - allows the system to send power to the wheel with the most grip. Not as strong as lockers, but will get the job done in most cases. The new FJ's have this, along with the rear locker, which, IMO, is an awesome combo. You can always add a locker to the 01-02 4Runner, though.
The benefits of a 99-00 are:
1) Rear Diff Locker.
2) Higher ground clearance for some 99 models.
3) Available 5-speed transmission.
So if this will be more of a daily driver with some off-road fun, then I'd suggest going for an 01-02. If it'll be for a dedicated trail rig, go for a 96-00 with a Rear Locker.
Personally, I've vote for a 02 Sport Edition."
Does that pretty much sum it all up?
Higher ground clearance on the 99's, what model did this apply to?
