Those with Weathertechs and rear heat
I too wasn't aware of rear heaters. Hmm..
As for the thread, it sure seems like it could tuck under the corner, but if not, I'd trim it.
It clears on the driver's side fairly well. You can't tuck it on the passenger side, but if you need it, a quick trim will unblock most of the vent. (well, it isn't even blocked, it is about 1" in front of the vent).
I'm not even sure if that rear heater has ever been used other than to test its operation in the life of my 4Runner...
-Charlie
-Charlie
I added a green light above it because at night I don't think anyone knows it exists:
Also added one in center console:
I remember in my '93 I had to trim my driver's huskyliner because it interfered with the pedal reaching full throttle. Looking back I may have been able to adjust the cable on the engine, but essentially I would push the pedal down as far as it would go and it was like 75%, putt-putting down the road; take out liner, pedal goes down farther and can accelerate quicker. That thing was already underpowered so I had to cut the corner off the liner or not use it at all.
[MENTION=124759]68ChargerJMP[/MENTION] thanks for the info. I will have to consider this when/if I buy back row mats. I don't have a full ride that often, but I always seem to be the go-to driver when the weather gets nasty; all my friends have little cars, lol.
side note, [MENTION=9]Jason B[/MENTION], what did you wire the led to above the rear heater? I'd like to do something similar. How is the led secured to the plastic surround? That's a useful addition!
I tried into the wire for the ect/power button, since those light up when the parking lights are on only.
or any of these will work.
Just drilled a small hole and the light fit right in, has a shroud around it so you can't see the hole you drilled. Get them at radio shack. Are any RS still around?
AndiGarage
