ShooterMcGavin
Here is what I am planning, eventually... Toytec coilovers up front with 600# springs, LC 80 front 8-wraps for my rear springs, LC tokico blacks for rear shocks. Diff drop up front, panhard adjustments as needed (drop bracket welded, most likely). I'm expecting 3" lift front and ~4" lift in rear, without adding weight.
I'm asking because I want to get a body lift in place before sliders go on, and I want sliders as one of my early additions.
Here is my question... I want to be able to clear 255|85R16, but I might do 285|75R16 at some point, as an option. Clearing the 255s at full stuff/turn is my bigger concern. I have a 1/2" body lift ready to install, but I'm not sure if that is enough. I don't want to lift ANY higher than I truly need to. I'm considering the 1/2" BL and then adding some material to the bump stops as I test it out (might be a suitable solution?). Or, should I just go get a 1" BL and be done with it?
