Where did you get this idea?
You're attempting to COOL the airflow of the charge through the throttle body by removing the coolant? The air intake sits right on top of, and is heated by the cylinder heads (where all the fire is). You have a metal that really likes to soak up and distribute heat bolted directly to another piece of metal that really likes to soak up and distribute heat directly in contact with a whole lot of hot little explosions... What temperature range do you think those explosions are? In a HEALTHY engine, your exhaust manifold temps can get close to 2K degrees. That's the exhaust side, so let's just ASSUME the intake side is only half that at 1K degrees right at the head with no cooling. Half that again just for the sake of argument, and then AGAIN to make it truly absurd. 250 degrees isn't that hot, but your intake charge is then going to be heated to 250 degrees.
Now, assume you're not doing silly modifications to an otherwise healthy (an assumption) engine for the sake of doing silly modifications to an otherwise healthy (an assumption) engine: if you have coolant (mostly water) running through the intake in a manifold designed specifically to counteract this thermal conduction, even at the super-duper argumentatively reduced temperature of 250, you're better off by 38 degrees at sea level.
I don't have any direct experience with this type of temperature readings on these engines, but the last engine I fiddled with anything that had me checking temps of various systems with an infrared thermometer (and it may just have been because I had one in my hand and was goofing around in the engine compartment) and more or less uncooled intake (this was an older engine) checked out at about 350 a few inches from the head. This intake, however, was hanging out pretty well in the open where airflow was able to affect things; the intakes on these engines are pretty folded up and compact and would not have even that minimal benefit.
So that's the direct effect of removing your intake coolant, the indirect effects are higher charge temperatures => less dense charge => less available oxygen for combustion => less engine output. In a nutshell, you just robbed yourself of several ponies IN THE BEST CASE SCENARIO.
A worst case scenario is runaway thermal buildup (serious structural damage to your intake and/or head resulting in dropped valve seats and the like), and slightly less worse is some nasty pinging and your engine tears itself apart internally.
To summarize: this mod is not doing you any favors.
Attention people who like "cheap" mods to their engine because they think it's cool or something: don't do this, it's not a good idea and could harm your engine.
