Throttle body help
Ehahn84
Hey all.
I took my throttle body off to clean and add a washer behind my spring assembly to help alleviate a higher than normal idle. In the process of doing so I think some of the wound up springs came undone. I need some help knowing what goes where. Could anyone help supply my with some good close up pictures as google is no help with this.
Thank you!
Google is no help because the throttle body is a non-serviceable part, according to the FSM. Even I haven't messed with the throttle body and I'm more adventurous than most. Got a junkyard near you?
I’ve checked the two in town without luck. Ext closest one is about 45 minutes away and has several 4runners.
2001ATL
