Throttle cable removal/reinstall write up.
5vzT4R
So I went to re-adjust my throttle body cables, and I over tightened my throttle cable and snapped the adjustment bolt in half, so I ordered a used one from a 1998 4runner. I searched for any info on replacing the cable and found nothing. So here is a write up to help those who may need it.
My old cable next to the "new" cable, here you can easily see how the adjustment bolt snapped in two, DO NOT OVER TIGHTEN lol.
Now on to removal.
Step 1: (forgot to get a pic) But open the throttle valve by pushing down on the lever, and remove the cable out of the "slot" and out of the lever.
Step 2: Loosen the adjustment nuts and lift the cable out of the bracket, 14mm wrench:
Step 3: Remove the cable out of the bracket holders circled in red:
Step 4: (forgot to get a pic, again) But unbolt the gas pedal, two 10mm bolts, and push it to the side to expose the clip holding the cable to the pedal. I found it difficult to leave the pedal bolted in. Remove the clip by pulling it and pushing to side, (or just play with it until you can remove it.) See here:
Step 5: Unbolt the cable bracket bolts bolted to the firewall, two 10mm bolts:
Step 6: This part would be easier with a extra set of hands, but easily done by yourself. Start pulling and pushing the cable out of the engine bay, through the firewall and out of the cab of the truck:
Pulling:
Pushing:
Step 7: Reinstall the new cable clip into the gas pedal bracket:
Reinstall everything in reverse order and that's it! I hope this will help somebody! If not, then thanks for reading my half ass write up!
i did the ame thing a few months ago, i was trying to "get better throttle response for free" and snapped it also. i took it to a shop to see if they could do it and they quoted me like $300 including the part. needless to say i called up the dealership and installed it in a half an hour....
No problem!
And yes, well I have adjusted them before. But they were loose again? So I then went to tighten them all up once again and bam... broke lol.
I just replaced the throttle cable in our 4runner because I could not stand how sticky it was. It's smooth as butter now. Took my about an hour to do the replacement. Got the cable from Rock Auto. Cost about $50.
Just replaced mine. It's pretty easy, I've removed it before.
I didn't think my cable was bad until I replaced it! It's about as smooth as the brake pedal now. So if yours is sticking or harder to press than the brake, I suggest replacing it!
I know it's all in my head and it didn't change anything, but it seems faster and a better throttle response since the skinny pedal is so easy to press now!
Do you know if all throttle cables are same length for 3rd gen? I need one for my 02
Sent from my SM-S737TL using Tapatalk
2002's don't have a throttle cable. Look at the backside of your gas pedal and you won't find a steel cable, instead a sensor that shows throttle position. This in turn is sent to the motorized throttle body and opens the valve.
