thunk after stopping
Hakabo
it seems to happen whenever i come off the brakes. its like a thunk. it doesnt really lurch forward (any more so than just letting off the brakes) but there is a noticeable thunk from somewhere under the vehicle.
I just recently purchased a 2006 4Runner with 88k miles on it that did that. When I took a look under the front, it was obvious the lower control arm bushing where shot so I replaced them and it got better, but didn't go away. The truck had this feeling I can only describe as 'heavy' when I was breaking. The I noticed some fluid coming out of the shocks. Took it to get looked at and was told the shocks were pretty much toast. Since I was planning on lifting it at some point, I went ahead and had the whole suspension upgraded to Bilstein shocks/OME springs and now it drives like a dream!
Not sure if that helps you, but that has been my experience so far.
i had somewhat of the same symptoms in my tacoma - there was slop in the drive axle that would kind of bind under stress. i have yet to get under it and look. are there zerks in the drive axle on an 08 4runner?
That "thunking" comes from drive axle slip yoke being low on grease.
That's a well known issue as mentioned already, there's even TSB on this.
There are 6 zerk points on drive axle if my memory serves me correctly. Keep drive axle greased and thumping will to away
seltzernator
