tie rod end angle after alignment
infinitysa
I just changed my LBJs before a big road trip, so I took the truck in for an alignment. I was looking underneath for a final inspection and noticed the tie rod ends were at pretty different angles. On the right side, the tie rod end is aligned to the LBJ, whereas on the left, there is a lot of angle to it.
Does this seem normal or should I take it back to the alignment place?
Adding: I am talking about the angle the the stud is relative to the body of the tie rod end.
https://imgur.com/a/Mw3vyYA
If it bothers you, reach in there and rotate it. That part is free to rotate around the ball (there is a ball on the inner tie-rod, so the part in between is basically free rotating, within limits).
-Charlie
erinobr2000
