Time for an allignment?
Granzyman
about 15 months ago i got an alignment after lifting my 4runner 3 inches...i experience very loose steering...should i get a realignment? and how often should i get one done?
I'm not sure if an alignment would help loose steering. What have other lifters done?
Its not like uncontrollably loose..but it happened the second i lifted my truck. actually might have been when i put on larger tires..
it may need a caster adjmt. it is common for the caster to be off after a lift. you should be able to get it close to spec, otherwise you may want to look at aftermarket upper control arms
