Time to replace Coilpacks?
haybeav
So yesterday I replaced my own sparkplugs for the first time on my 2000 4runner with 83k miles (just purchased last month). It was actually easier than I expected except for 5 of the 6. I'll let you take a guess which one gave me the most trouble.
I bought the OEM plugs from the dealership a few weeks ago and finally got around to installing them yesterday. Had no issues until I started getting to the plug closest to the firewall on the drivers side. When I reached down to pull up the rubber coil assembly, the rubber stopper that sits on top of the plug did not come up. I couldn't reach the plug with my wrench so I had to spend an hour trying to pull out the rubber around the plug itself. Once I got it up, I replaced the plug.
At this point, I assume I'll have to replace the assembly that is missing the rubbber stopper. My question is whether I should just replace all the coils packs and assemblies while I'm at it? What should I expect to pay in terms of parts? How long to the original coils last before having to be replaced?
Just for fun, this pic shows the assembly after I pulled it out with what looks like some corrosion.
Whatever choice you make be sure to use the Toyota / OEM part. Especially for plugs, wires, injectors and (I assume) coil packs.
Bought from a dealership! No way dude. Buy legit OEM / Toyota dealer parts online from dealers in AZ/TX. Google: "Camelback Toyota Online Parts" Sales.
About the coil packs, I'm still on my originals for most part. I replaced one to get rid of a misfire code but it came back 4 months later and disappeared again so I don't know if the coil pack really was bad after all. Currently at 220K miles.
Thanks for the heads up. I thought parts from a dealership were all OEM. Did not realize there was a difference.
This is my first 4runner and the first time working on my own vehicle so I'm kind of a newb.
IF you are new to toyota, keep this in mind, the most frequent repairs/services are oil changes and brake shoes/pads. Any other repairs are less frequent. So check with us before doing any other repairs. Most owners replace parts based on their past experience with non-toyota cars/trucks.
My 4runner has almost 190 K and so far with OEM alternator/starter, etc.,
Majority of toyota electrical and AC items are DENSO. Buy OEM or denso products if you want the toyota reliability.
The point I was trying to get across was instead of paying $200 for parts at local dealer buy the same Toyota part for $140 from a dealer but online.
Camelback Toyota has special pricing from their internet sales dept. Same dealership, just different method of commerce, 25-30% off.
Ahhh, I see what you're saying. Thanks for the tip.
Side note: Will running without that rubber stopper that used to sit on the spark plug do any damage?
If the only problem is the coil boot (aka 'rubber stopper'), I'd try replacing that. I don't think Toyota sells them, but NAPA does, $20 each, BEL 702450. Then learn to lubricate the boots each change with dielectric grease, also at NAPA.
Spark Plug Boot (Coil to Plug)
If you do need a coil, forget the stealer--online or otherwise, unless you like paying double to get a red box. The OE coil is a Denso 673-1201, available at Amazon for $64.95 (Prime eligible). SAME EXACT PART, half the price. I would never just swap out coils for no reason, the vast majority of those coils will outlive the truck they came over in--especially if you grease the boots each time.
http://www.amazon.com/Denso-6731201-673-1201-Ignition-Coil/dp/B002Y39NFY/ref=sr_1_1?ie=UTF8&qid=1375757268&sr=8-1&keywords=673-1201
MaximussK
