Time to replace suspension components -- advice?
ssk1
Hey guys,
Everyone here has been really helpful in responding to my other posts, so thank you guys for the support.
I picked up a 2001 4Runner SR5 with 168k miles on it now, and after making sure the engine and drivetrain were in great shape by my mechanic (used to be somewhat handy myself, but living in SF and not with the parents any more, I no longer have access to tools and a dry garage space), the next piece of work I'd like to fix is the sagging rear.
It's got all original suspension parts (front and back springs and struts), but on advice from my mechanic, I should only work on replacing the rear spring and struts. He believes that the front end is still in decent condition (I would tend to agree).
Now, I've read the sticky on "Lifting your 4Runner", and have read posts on google, but it's a lot of information and confusion. So with your collective wisdom, T4R, I kindly ask for your advice on my goals:
1) I want to keep the 4Runner mechanically reliable at this time, and for the foreseeable future (getting married, relocating, and will have to find a new job :doh:) and thus I can't afford an overhaul on the entire suspension system. I've read lifting the 4Runner a certain amount without upgrading certain components (CV, control arms, diff drop, etc.) would lead to increased wear on said components, which I want to avoid.
2) I also can't afford larger tires as I have no justification to buy them now (although it would be sweet), I have nearly brand new Michelin 265/75R16's on.
3) If possible, I'd like to achieve a mild lift, so would the OME 906 2" lift work while keeping the front end STOCK (mechanic says front is in good shape, and I would rather replace the springs and struts at the same time once I can afford it). What strut would pair well with it for a comfortable ride? Would a lift like this look silly without a mild lift on the front end?
4) I would like to keep the suspension more on the "comfortable" side; this car is my DD and I wanted a 4WD not because I wheel it (a possible future hobby), but because I rock climb, and some back country roads have rough terrain where 4WD and higher ground clearance is useful (and so I can hop curbs and medians in the city :laugh: )
TL;DR -- On a budget, so what strut/spring combination to replace sagging rear end while keeping the ride comfortable, and would a mild 1-2" lift make the car look funny with keeping the front end stock (for now)
Thanks guys!
01-02 were the lowest 4runners. I would go with 99 tall springs for the rear if you're keeping the front stock.
Would a Tokico Trekmaster and an OME 906 2" spring in the rear be a good combination for on-road comfort? Can I leave the front stock for now, without it looking silly? Or should I add spacers to the front too?
I'm not so worried about having a shock with more flex for off-roading since I won't be doing that often, and when I do it won't be too extreme.
I don't have experience with either of those. From what I've read the 906's are a heavy duty spring so if comfort is important to you I'd stick with stock 99 tall springs.
I also think the 906's would give you quite a bit of rake with your old stock front springs.
I agree. Or go with a 1.5" spacer if you just want a little rear lift.
Thanks for the feedback guys.
I double checked and the OME 906's are a 2" lift "light weight" spring. I was thinking of pairing this with a Tokico Trekmaster (which I understand are the OEM shocks) and maybe using Daystar 1.5" spacers up front. Do you think this would give it a more appropriate rake?
I think you might be in for a rude awakening depending on what you consider "light weight".
If I was sticking to a sub-2" rear, I would trim pack new 99 coils.
(I REALLY wish the 3rd gen rear coil market was stronger under 3"...)
The 906 are much beefier than what the website says. Its a much stiffer ride, but I enjoy it. Feels planted to the road but my daily commute is all highway.
Excuse my ignorance but I'm a noob (to upgrading not offroading) Are you saying that a 3" lift will be considerably stronger in rear than a 2" because the coils are better in that bracket?
Its kinda hard to get specifics or even ask the right questions with so many application variables....its kinda overwhelming lol. Should I just start my own thread? Seems like the more I detail what I need the more detailed response I will receive...
I think that was directed at me - I apologize if it was worded strange.
I meant to say the market for rear spring choices (to me) is difficult.
it's stock 1" springs, bunch of spacers, oversprung 2", maybe ok 3"? cheap, too-soft 4"+...
I really wish there was a way to run "affordable" coilovers in the rear! ;p
Ome with bilsteins is probably the best ride under 3.5". Maybe superflex coils in back and TRD front coils on bilsteins in front, too
Ok, so I spent a few more hours researching this topic on this forum, and have pretty much narrowed down my options:
Stock OEM Setup, 1"+ Lift --
Tokico Trekmaster Front Shocks [GU3535] - $93.99/ea (autoanything.com)
Tokico Trekmaster Rear Shocks [GE3536] - $73.99/ea (autoanything.com)
'99 Tall Front Driver Spring [48131 - 35350] - $109.15 (toyotapartszone.com)
'99 Tall Front Passenger Spring [48131 - 35400] - $99.97 (toyotapartszone.com)
'99 Tall Rear Springs [48231 - 35210] - $75.18/ea (toyotapartszone.com)
Total - $695.44 + additional misc. mounting/replacement hardware + shipping = [estimating $800+]
Mild 1.5" - 2" OME Complete Lift Kit --
OME Front 880 Stock Weight 1.5" Lift
OME Rear 906 Stock Weight Medium 2" Lift
OME 90004 Nitrocharger Front Shocks
OME 60028 Rear Comfort Shocks
OME Front Driver 5mm Trim Packer
Pre-Assembly of front spring/coil + new top mounting hardware
Total from toyteclifts.com - $935.24 + $48.48 = [$983.72]
Total from rocky-road.com - $924.27 + $63.90 (with insurance) = [$988.17]
I'm leaning towards the OME complete kit; it's got pre-assembly and new top mounting hardware/bushings which I would need to perform with the "Stock" upgrade path. 1.5" front and 2" rear is mild enough for my needs. I'm not looking to re-doing the suspension for another 5+ years so, I need to make this decision count. I really don't see rock-crawling in my near future, just light duty trails out here in California (Yosemite, Sonora, San Joaquin Valley area)
I looked at my tires again and was mistaken, they are 265/70/16, so ~30" diameter. Having looked at pictures, they are going to look tiny if I go any taller, and they are brand new tires so I won't need to change for a couple years.
I'm itching to pull the trigger on the OME kit, but I just spent ~$2k on putting my 13yr old dog to sleep, so I know my more sensible fiance would tell me wait a few months on putting another ~$1k on credit...
Any other thoughts/advice? I hear steezemcqueen can give a discount code on toyteclifts.com?
Found a 10% off promo code for Toyteclifts! Guess I'm pulling the trigger... Case Closed!
thanks for the feedback gentlemen!
This is similar to my needs: replacing stock, want it to be long term investment, except I'm in norCal. I don't do any extreme offroading but the roads I have to drive are extreme. About 50% paved/ 50% old logging roads (30 mins drive on pavement then 20 mins uphill to work for example). And its my daily driver so I too need to make it count. I was looking at the 7.2 from sonoran steel but I'm gonna check this one out as well...any other suggestions?
tuṣṭāva
