Timing Belt and Water Pump Job: How much and how difficult?
USSEnterprise
I have a 96 4WD with the 3.4. I am at 63k since last belt change. How difficult is the job? Is there a webpage that runs through the procedure? Will I need to buy any tools, like a cam holder?
I am about 500 dollars into the parts for my replacement(all toyota!)
Dont do the belt every 60K. Thats dealer crap. Go 90K - 105K between belt changes. The only special tool you need is a tensioner compressor to make it easier
Just got back from the dealer 10 mins ago. Had the belts and water pump done.
Labor = $530.30 (inc. state insp +emmissions)
Parts = Timing belt - $56.99
Alternator v belt - $12.53
V ribbed belt - $10.81
V belt - $27.13
Water pump - $136.76
Antifreeze - $28.05
Tax = $55.65
Discount - -$13.00
TOTAL = $850.62
Re: Re: Timing Belt and Water Pump Job: How much and how difficult?
What is your parts list? The other list above looks to be only $220 in parts...
I would agree with the mileage statement, and as far as the tensioner compressor, u can just use a vice to slowly compress it, then insert an allen wrench through the holes to hold it in place. Don't think you will need a cam gear holder. Done a couple of belts without them.
i was about the same in parts as well all toyota i replaced all the moving parts that are related to the t belt.
t-belt
3 drive belts
water pump
thermostat
belt tensioner
uper idler bearing
lower idler bearing
seals
i think there was more partsi replaced but i dont remember them all these are the more main parts.
What is 'book time'?
According to my receipt they charged me 5.5 hours labor for just the belt replacements.
... and to make matters worse, my engine now sounds like a weed wacker and an electric lawn mower having a fight. There is a horrible, really loud whirring sound coming from belt area.
Better look under the hood, might have stole your motor, and replace it with a wed waker. No really I would deff. take it back by the shop.
how long ago did you have it done? the belt will make a little noise at first while it's braking in
as for what to change, if you're around 100k miles it's good to do the seals, and t-stat while you're in there. if you want to go further, grab a tensioner and an idler pulley too, as the idlers are known to pop after time.
as always you should do the water pump and drive belts. and pleaseeee use genuine toyota coolant.
The work was done two days ago. I know what you are talking about there, but this noise is extremely loud and obnoxious. I'm really pissed with the Toyota tech for letting it leave the shop like that since when I took it back (2 hours after picking it up) he agreed that something was not right. It's going back in on Monday to be remedied.
I did not experience any additional noise after my timing belt and water pump where replaced.
I would bet $100 that the noise is coming from the cam sensor wire hitting the cam pulley. No way should the belt make any noise after replacement. It doesnt need to 'broken in'. No such thing. I'm not gonna start the debate again, but I think its rediculous to replace every damn thing behind the timing cover. I hate the red toyota coolant. To me it seems a bit more corrosive to gaskets and seals. As far as book time, it's an industry standard of time that is what shops use to figure labor times and prices. There are labor guides that shows labor time for any particular job. If you got charged 5+ hours just for the belt replacement, you got way overcharged unless their labor rate is almost half of what everyone charges. Most shops out here charge about $85-$125 per hour
1997 Toyota 4Runner 4 cyl Two Wheel Drive Automatic 140,00 miles
sat for 4 days-
when i started it up today it made a couple of poping
noises.
I let it idle down /warmup
when I would accelerate in Reverse or Drive - it would make a series of pops again
runs a little rough
are these symptoms of a timing belt about to fail
