timing belt job - crankshaft pulley holding tool?
vanderwiel
Turns out the runner needs a waterpump/timing belt job. According to the instructions included with my timing belt kit, I'll need a crankshaft pulley holding tool handle (09330-00021), crankshaft pulley holding tool (09213-54015), and a puller (09950-50010/09950-50012).
Does anyone know if there are cheaper alternatives available? The shop that diagnosed it charges $90/hr (has the tools), but my mechanic charges $20/hr and said if I can get the tools he can do it.
Any input would be greatly appreciated.
Use the search bar at the top and type in things like "timing belt change" or "Crank bolt removal". I have seen at least 6 different DIY tools made on the cheap for doing this job. Have fun.
Love my chain wench! I used the old timing belt to protect the pulleys
I have done three timing belts in the last year and this is the tool I used to hold the crank. https://www.amazon.com/gp/product/B012UUE1DY/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
I used this to remove the cams to change cam seals
https://www.amazon.com/gp/product/B00VFPOF1E/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
I used this tool to remove the crank seal and cam seals
https://www.amazon.com/gp/product/B000FPYW4K/ref=oh_aui_detailpage_o07_s01?ie=UTF8&psc=1
I used this tool to remove harmonic balancer and crankshaft timing pulley to get to seal
https://www.amazon.com/HFS-Pcs-Harm...1472743035&sr=8-37&keywords=crankshaft+pulley
Using these tools made this job 10x easier than when I did the first one without them.
Use a torque wrench to tighten the crank bolt with the chain wrench wrapped around the crank pulley with rags to protect it. This is how the Toyota techs do it. Same with cam pulleys.
I do have a chain wrench, but always have been afraid of scoring the pulley even by using rags with this method. Where do you suggest putting the chain? into the ''valley'' of the pulley (where the belts run), or on the top of one of the ''wall'' of the pulley (which separates each belt driveline and where a gouge should be less of a concern)? I'll probably try my chain wrench when I'll do this job.
I do have a chain wrench, but always have been afraid of scoring the pulley even by using rags with this method. Where do you suggest putting the chain? into the ''valley'' of the pulley (where the belts run), or on the top of one of the ''wall'' of the pulley (which separates each belt driveline)? I'll probably try my chain wrench when I'll do this job.
If I were doing it with a chain wrench, I'd use a piece of the old V-belt you just took off, cut it to length of one circumference, fix it around the pulley with a little duct tape and put the chain wrench on top of that...assuming you are doing your aux. belts. Me, I have a 2x4 rig that works great and cost me parts I had lying around.
With rags, it won't damage the pulley. I just put the rags wrapped around the pulley, have a knife handy to cut a hole in them if needed for the breaker bar/torque wrench, and tighten/loosen the bolt. Can use your old timing belt, or what [MENTION=10169]TheDurk[/MENTION] does.
freddygino
