Timing belt
Dry-fly
Member
Hey, guys. Im about to have the timing belt/water pump replaced on my 07' 4runner with 90k on it. The dealer is actually charging less than a couple of smaller shops that specialize in Toyotas...One shop mentioned doing crank and cam seals at the same time, they wanted like $1300. Dealer wants $835.....anyone else run into this? Is there a list somewhere of exactly what Toyota recommends replacing at the same time?
The shop that did mine said crank and cam seals if not damaged, are typically done on the 2nd TB replacement. I had the WP, TB, drive belt, tension and pulleys done on mine at 110k. Got the parts myself, had a local shop do the work, I think I was just under $800 total.
After some more calls, everybody is within about $100, except for a flyer that wanted $1300. I found a recommended independent dude that will do everything for right under $1000.
a toyota dealer here in colorado will do a 90k service for $1200 which includes t-belt, water pump, thermostat, pulleys, transmission, coolant, differentials, and transfer case service.
