Timing Belt
cdmasm
My 4runner has 60k on the timing belt, does this need to be replaced ASAP? I know the manual suggests replacing it every 60k, but how many more miles can be put on these things?
Although I have never had any break on me in the cars I have owned (non toyota), when I did replace them I did see enough wear to justify the replacements. Some I changed early, others I changed late, but I always changed mine close to the mfg. specified intervals and always bought the OEM brand belts. I'm not saying you should get it done yesterday or your engine will die a horrible death. All I am saying is if I were you, I would plan on doing it at the next convenient maintenance opportunity you get. Also plan on doing some other inspections and replacements while you got the thing torn apart. You are in there anyhow so you might as well.
What year is this Runner? I replaced mine in my 99 at 94k, and the belt still looked like new. We also have a non-interference motor, so if it breaks, nothing else in your motor is harmed. It just shuts off.
Brett
Brett
Is this true for all 4 runners? I have a friend with a 1990 V6 4runner I am doing some research for him on his timing belt. Also Is there any place that has a service schedule for this particular model?
The http://smg.toyotapartsandservice.com website only goes back to 97 for the 4runner
Duck -- You may be able to find an owner's manual on eBay for your year model. There is usually a service schedule of some sort in there. General rule of thumb is to replace the timing belt every 70,000 to 80,000 miles.
Mike in AR
workingwheelswnc
