skythefly13
I am looking to find out when the timing belt needs to be replaced on my 99 4x4 6cl., can anyone help me out on this?
fireteacher said:look at the timing belt cover, some have said that they have found that their's has a "stamp" indicating milleage it was changed.
you could howerver, go back to the dealer and HOPEFULY they could find out if it has been done but there is a slim chance in that!
sucks to bite the bullet though on double work but its better to be safe than sorry. you could remove the cover and see yourself the cond of the belt.
Pyrohazard said:My 98 runner has 126500 miles on it and I have not changed the timing belt on it. So I will see how long I can go before I have to change it.
fireteacher said:jev, did you read the post where i mentioned that the 3.4 is a non-interference motor? nothing will happen to the motor if and when it breaks.
(glad the deckplate worked out!)
fireteacher said:http://www.aa1car.com/library/2003/us70343.htm
do a search on yotatech also...lots of mechanics working with toyota and alot of knowledge as far as maintenance goes.
someone even said that gates was wrong in their info...midiwal i believe. call your dealer as well as doing that. tell them to show you where it says non interference. pm some people and see what they say. if you find out other wise please let me know, but, i have gone to the dealer as well and there are a few other sites to check out as well.
animator said:I think someone on yotatech pointed out that Gates has been wrong on more than one occasion when declaring interference and non- engines, so I'm hesitant to take their word on it.
There is a post somewhere over there that shows the actual valve and piston clearance measurments, which seems to me to be proof enough that the 3.4 is NOT an interference engine.
