highmilesrunner said:i just had mine changed at 268K for the first time, because the guy i purchased it from had never replaced it. the mechanic said it was just a little fuzzy was all. my runner is a 97 SR5 4x4, and i believe all 3rd generation runners are non-interference motors, meaning if it does break while driving, no damage to engine will occur.
It is stories like this that made me think to delay changing my belt. I now have 95,000 miles and I plan on going to about 120,000.The Dude said:I'm at 145,000 miles on my 99 right now and have not had my timing belt changed yet.
00t4rlimited said:Almost all toyota FE style cylinder heads with a 22.3 degree valve angle are non-interference engines. What that means is that if the timing belt does break & the crank still spins the pistons will not hit the valves even with the valves fully open. This is acheived either by valve releifs in the pistons, or valve angle itself.
Well, it turns out I wait on my 01 till I had 150,000 miles on it. I know, I should done it sooner. Some sides of the belt were were worn off and you could see the inside of the belt. Maybe a inch of two were wear was visible. No cracks at all, but changing it was a good idea.My 4Runner has 148K miles all on the original TB&WP - glad to read 5VZFE is non interference cause I've been stressing about it. It looks to be easier DIY job than most vehicles - lot's of room to work after radiator comes out. This summer I will tackle it.
Boy, I think that is a bit of a stretch. I guess if we follow your logic we should say if you drive a VW or a Hyundai, (two makers have have the worst repiar record according to Consumer Reports), if they break down and cause a wreck, we should sue the owner of the car??? And of course if you driving a old classic car or a new Fiat forget it, you might as well say they are guilty for driving such car.:roadkill:I am not a lawyer but I would think if an accident was the product of a failed timing belt it could turn into a case for negligence.
