Thai
Elite Member
Timing Belts
by Jim Kerr
Vehicle maintenance is seen by many drivers as doing parts replacement or repairs only when the vehicle starts to perform poorly or breaks down. While many vehicles can be driven until something does go wrong, having the vehicle maintained regularly means you can have repairs done at your convenience. Replacing some items as part of a regular maintenance schedule can also save you hundreds of dollars!
Over time, rubber parts of a vehicle start to harden and break down. This is especially true of parts in the engine compartment because of the higher heat levels. Many of the parts such as heater and radiator hoses, and power steering and alternator drive belts are easily inspected by opening the hood and visually checking the parts for cracks and worn spots. However, many vehicles have one rubber belt that is not easily checked: the timing belt. It is installed under a plastic or metal protective cover.
Timing belts are tough rubber belts with a centre core of cord material. The cord material gives the belt much of its strength yet it is still flexible. Most belts are about 25mm (1 inch) wide and have a smooth outer surface and evenly spaced rubber teeth moulded onto the inside of the belt.
The timing belt has a very difficult job to perform. Starting an engine causes hundreds of parts to move. The timing belt has to move many of these parts and exact timing of that movement is critical for proper engine performance. If the parts are not moved at the proper time, serious engine damage could result.
Located at the front of the engine, the timing belt is driven by the crankshaft sprocket and drives the camshaft sprocket. Some engine designs use the timing belt to also turn another shaft that drives the ignition system. As the camshaft is turned, it opens and closes the engine valves to let the air and fuel mixture into the engine and the exhaust gases out. Installing the belt even one tooth out of alignment will cause the engine to run poorly. If the belt is more than a couple teeth out of alignment or it breaks, then the engine's valves will be open at the wrong time and the valves could be hit by the engine's pistons. This bends the valves and requires replacement of the damaged parts.
Some engine designs are called "free turning". This means there is always clearance between the pistons and the valves so damage will not occur if the timing belt is broken. Most engines are not free turning because the extra clearances have been eliminated to reduce exhaust emissions and increase engine performance. When a timing belt breaks on any engine that is not free turning, replacing any bent parts can run into several hundred or thousands of dollars. The best way to avoid this is to have the timing belt replaced at the mileage intervals specified in the vehicle's owner manual maintenance schedule.
Some engines use a steel timing chain to turn the camshaft instead of a rubber timing belt. While these chains do wear, specific replacement intervals are not listed in the owner's manual as they are for timing belts. Timing chains become noisy when worn and are usually replaced before major engine damage can occur.
Many manufacturers recommend changing the rubber timing belt at intervals of 80 to 100 thousand kilometres. Some new belt designs have change intervals as high as 160 thousand kilometres, but on one model of Fiat automobile, the change interval was as low as 50 thousand kilometres. Be sure to check the schedule for your vehicle or check with the dealer service department. Remember, a broken belt can cause very expansive engine damage!
There are times when the timing belt should be changed sooner than recommended. This is when oil or antifreeze has leaked onto the belt. Both oil and antifreeze attack the rubber timing belt and can cause the belt to fail prematurely. Any fluid leaks at the front of the engine should be repaired as soon as possible to prevent damage to the belt. If you do some of your own maintenance, such as replacing a thermostat or waterpump, be sure not to spill any antifreeze down the front of the engine!
The procedure for installing a new timing belt on the engine varies from vehicle to vehicle. A few are simple and may take only half an hour. Others are difficult to change, requiring the removal of many parts and three or more hours of labour. Exact timing and correct tensioning of a replacement belt is required for proper operation and durability. Special tools may be needed so this is one job best left to a specialist with the right equipment.
by Jim Kerr
