Tire size with Daystar and 18" rims
Lafawnduh
So, I am having a Daystar 2.5/1 lift/leveling kit installed tomorrow on my 2008 Limited. Reading through the sticky threads on suspension / tire sizes, it appears that I could get away with up to a 32" tire.
My question is with these rigs is it the diameter of the tire that causes most of the rubbing issues or the width? Right now I have 265/60/18 which are 30.5" in diameter and 10.7" wide. Is it reasonable that a 255/70/18 (32" x 10.2") would fit or is a 265/65/18 (31.5" x 10.7") going to be a lot safer bet for no rubbing?
It just seems like there are very few bits of info when running the 18" wheels and I can't afford to buy new rims too.
Thanks for any insight.
I am currently running 255 70 18s with FJ/Icon coils and 5100s. It took a little bit of trimming to make the tires not rub up front. Nothing substantial though.
Shameless plug -- my tires are for sale if you're interested. Only 6,000 miles on them :yo:
265/65/18's will work fine. You might have minimal rubbing on the fender liner but that should be it. Here are some pics of mine with 265/65/18 BFG AT's.
Sounds like the slightly smaller tires may be the way to go to avoid a hassle. Aren't those BFG's load range E? I was hoping to find some in range C, but those appear to be for 17" rims. Load range E is a bit more than I need.
Yep. They were E rated tires and were installed by the previous owner. The tires I have now are essentially the same height (265/70/17) but are not E rated. There is a noticeable difference in acceleration with the lighter tires.
Great, thanks for the info. I'm going to have to give up on BFG AT's and look for something hopefully in C or D range.
Great looking ride by the way. Super clean!
This is what it looks like now with Falken AT3's. For the money, these tires have been very good.
If the Daystar lifts you more than 2.5 you may get rub on the mud flaps in front due to lack of caster. I have 275/65/18 with a 3/2 lift and I rub the flap at almost full lock with slight compression. I just need a heat gun to soften it up and flatten it a little.
Edit. I also have spacers which will definitely add to the likelihood of rubbing.
I have the same spacer lift. I got 265/65/18 and got slight rubbing on left fender liner.
I finally spent 20min to move it forward. It is quite easy as shown in this link: Toyota 4Runner Wheel Spacers
Drill new holes and adapt liner to use the same screws and clips
Agreed. I have the Cornfed 2/1 lift, and went with 265/70/17 KO2's (equivelent to the diameter of 265/65/18 at 31.6") and I had slight rubbing in reverse while turning on the front fender liners. I moved them forward. I also had a slight rub on the bumper where it tucks into the wheel well, so I broke out the masking tape, and dremel, and made some factory looking cuts.
I have no trouble making some slight modifications or trimming to fit the tires. More curious of if the larger circumference of the 255/70/18 would be MORE prone to rubbing than the 265/65/18 which is a little wider, but not as tall.
I guess the 255's are known as "pizza cutters" because they are so narrow.
Thanks for the input.
I have 34's on my Limited with stock 18" rims. Also have 1.25" spacers (to clear stock UCA) and did a bit of trimming.
For OP, 275/70/18 is more like a 33. The only reason I say this is because I was looking at the exact same tires... Regretting not getting them...
H.Sikina
