Tire sizes with 2.5" lift
Mxbuti
I'm getting the daystar 2.5 inch lift kit from summit and wanna know/see what tire sizes fit good without rubbin, im wishing to be able to run 33 12.50's with it but 10.50's could be a second choice.
as for wheels i picked up some stock fj cruiser wheels, sandblasted them and had them powder coated black, i'm not sure of the back spacing and i'm not willing to run wheel spacers to make the tires clear.
thanks for the input
Can you run a spacer and like a 11.50 wide tire? that would look ok?
I'm curious about that too. I'm getting the 2.5" Daystar spacer lift. I am looking a Nitto Trail Grappler 285/65 18 tires with an 18x9 wheel. Will it fit without rubbing? The height is 32.83 and the with is 11.93.
I've got a 2.5 inch spacer lift and im running 32x11.50s but I dont think I would wanna go any wider. Also with mine having the 3rz I wouldn't wanna go any bigger without re-gearing. I've tried the 33x12.50s off of my friends tacoma but there was some major rubbing going on, however, they were on a 10 inch wide wheel.
I just got back from the local wheel and tire store and they measured something in the front and said that 285/65 18 will be no problem with a 2.5" lift.
i have a 2.5 skyjacker for front and have 33/12.5 and they do touch on piece but you do have to cut the inside piece off of a piece of the plastic that blends the flares with the running boards
they said mine would work too until they put them on then it popped a piece of plastic off before i got out of the lot...
2.5" Lift w/ 275/60R20
I have a Daystar 2.5" lift on my 2016 Limited, would 275/60R20's fit without rubbing?
