tires
redrock
well here the new guy questions again. I have a 3"2" lift on my 03 sr5 v8. i would lie to now if i could go with a 255/85/16 tire without problems ??? I now i might have to do a little trim job on the inner fender but as far as the tire it's self any problems. anyone else running this tire ? maybe a picture ? thanks for your help.Donny
I don't think that tire size should cause a problem with the amount of lift you have. I'm running 265/70R17 tires on my unlifted SR5 with no rubbing issues.
I am looking into the Cornfed 3/2 lift. Since you have the lift I'm looking into, I have a couple questions. Does the rear end look lower than the front when you are standing off to the side of the vehicle? Does the running board (if you have one) tilt front, back, or is it level?
Today I jacked up my vehicle measuring a 3/2 lift to anticipate what it would look like. After raising three inches measured at the front wheel well and 2 inches at the rear, the rear seemed a bit low. Could be something about the way I had it jacked, but just wondering what others experience has been. I would prefer either a level look or to preserve a bit of the "rake". Don't like the lower rear end look, which I had plenty of with my previous 94 4Runner.
lift
hey gimmie a couple of days i will post a picture.I think the rear is still about 1/2" higher than the front. hope that will help you make the desicsion.
Thanks, it would be helpful to see a photo. I'm still a little confused on how to post photos on this site. How do you like the ride with your 3/2 lift? Do you have stock wheels or did you buy custom rims?
