To Repair, Replace or Retire?
Sounds like if the press switch doesnt do the trick your next step would be the pump or running thicker oil this was a problem with the chrysler Sebring v6 motors when the water pump goes bad because its driven by the timing chain it will fill the crankcase full of coolant and even after the repair you have to run a thicker oil because the coolant washed everythung down and caused enough wear to the oil pump to make insufficient pressure
Jhunt
