tool for separating tie rod ends
baja1
thought I would finally tackle the LCA bushing and tie rod ends, didn't get far! I gotta order a tool to separate these....big hammer didn't work, whats the tool I need?
so instead I tackled the starter contact issue......is nothing easy on these cars?
My '98 is a little weird for some reason and there isn't enough clearance because of the backing plate for any other tool... The only tool I found that worked is the OTC Outer Tie Rod Remover(p/n7503). A little expensive but on the plus side it works on everything else too.
Rented a tie rod separator from Oreilys when I swapped out my steering rack. Pickle forks didn’t have a prayer at breaking the end free. The separator fit perfect and doesn’t beating with a hammer. Took all of 30 sec per side.
AutoZone loans tools for free, leave a deposit when tool is borrowed and full refund
when tool is returned. I used their tie rod separator when I replace my lower ball
joints.
alexaturner
