Torque Curve b/w V6 vs. V8
So if you are not concerned with aggressive driving and more with the mpg why are you so happy with the V8's torque band :lmao:
In all seriousness though, I have had both a V8 and V6 4runner and love both engines. The V8 does have a little more power, but the V6 is more than sufficient. It has never held me back once and I wheel with guys with V8's regularly.
I'm happy because I cruise around town below 3000 rpm and still be one of the first off the line
Damn, you guys must drive like old ladies! :lol:
Don't you ever merge on to a freeway, or blast away through a toll booth? Hit that skinny pedal a little and live it up. I guess it's just weird to me that anyone would buy a V8 and keep it under 3000 RPM!
I've had several V8 Mustangs in my past and they all regularly saw the entire RPM range. The older 5.0L engines would really start to drop off after 5000 RPM, but the newer 4.6L Mustang engines keep on pulling right to the redline. They are all a blast to drive and I'd drive them that way. I'm a closet Mustang freak, in case you were wondering.
It is all about atmosphere. When i had my M3, i went fast...and paid for it via speeding tickets! :D When i am in my G, i just don't feel like going fast. Merging does not require me to have a lead foot...with the V8, i accelerate quick enough with just light pressure on the gas pedal. :) To do the same in my Sienna minivan, i have to use more of the powerband to get up to speed due to its smaller higher-revving engine.
That is because your V6 4runner has BFG M/T while Josh's V8 4runner has the highway Nitto TG! :D (Sorry Josh, i just have to get you one more time....)
That makes me think differently about my V8 love, still have to drive the 6.
What someone said about the timing belt. When I changed mine at 90k is cost me $350 at the dealership, not $1k. Don't you have to change the plugs in the V6 more often? I know it's 120k in the V8.
Unless you are towing a 5000lb + trailer at 75 mph it makes no difference.
Sources of torque curve of the two engines:
V6 = www.tundrasolutions.com/forums/attachments/tacoma/11846d1142555992-engine-overview-1grfeeng.pdf
(see page 3)
V8 (prior to VVTi) = http://www.toyota120.com/GenDocs/2003_4Runner.pdf
(see page 7)
Disclaimer: this is all based on me drawing a line down and across (with some extrapolation)...so, the torque figures are not 100% accurate, but should give you an idea of torque curve differences between the two engines.
4.0 V6 1GR-FE approximate torque % (torque at specific RPM divided by max torque):
Max Torque listed is 282 ft/lbs at 3800 rpms
1000 rpm = 220 ft/lbs over 282 ft/lbs = 78% of max torque
2000 rpm = 250/282 = 88.6%
3000 rpm = 260/282 = 92.8%
4000 rpm = 275/282 = 97.5%
5000 rpm = 255/282 = 90.4%
4.7L V8 2UZ-FE:
Max Torque listed is 320 ft/lbs at 3400 rpms
1000 rpm = 270/320 = 84.4%
2000 rpm = 285/320 = 89.1%
3000 rpm = 310/320 = 96.8%
4000 rpm = 290/320 = 90.6%
5000 rpm = 230/320 = 71.9%
Conclusion: from my point of view, the V8 engine (non-VVTi) definitely is designed for low end power...the torque curve clearly favors low rpm torque over high rpm power. The V6, on the other hand, is a more modern design with VVTi...and this VVTi technology is clearly reflected in its flatter torque curve (shocking finding for me!). The 4.7L V8 gives you a lot of torque early, but falls pretty quickly after it peaks at 3400 rpm.
The V6 clearly cannot match the V8's low end torque production...because there is "no replacement for displacement." That much is true. However, the V6 numbers are far from being peaky nor anemic...it produces a respectable 78% of its max torque as low as 1000 rpm...and jumps up to 88.6% (matching the V8!) at 2000 rpm. What is nice is that the torque stays there after it peaks at 3800 rpm...all the way till 5000 rpm (90.4%)...you can thank VVTi for that!
What does this mean? I have no idea. You guys can come to your own conclusion. Many will argue that the V8 produces power where a truck needs it the most...and where off-roading needs it the most. Others will argue that the V6 is fully competent in the lower end, yet still provides excellent response at higher rpms. Your miles may vary....
NOTE: in 2005, Toyota added VVTi to the 4.7L V8 engine...unfortunately, i do not have the torque curve for that engine. I am sure that VVTi would improve the 4.7L V8 engine torque curve at higher rpms, thus making it as flat as the V6's curve.
The OEM plugs on the V6 are supposed to be changed at 30,000 miles. Of course they can be replaced with long-life plugs like the ones that come with the V8, so it's really a non-issue. Besides, I wouldn't leave the same plugs in my engine for 100,000 miles, much less 120,000 miles no matter what kind of plugs they are. No way I'd ever do that.
Oops... Guess it's time to change the plugs then. I tried to have it done and the tech told me to just wait until 120k, it wasn't worth it to do them at 90k.
The V8 is a BETTER engine. Not only because it is more powerful, it was designed with a more difficult life cycle in mind. Everything on it is built to last. Cast iron block, forged iron internal components and the Denso 32bit ignition system which attributes to its smoothness. The V6 has a generic toyota system. Not only is the V8 "physically" better and more stout but the electronics that surround it are better as well - case in point the spark plugs.
Weren't there stories of cracked iron block on the V8?? Or how about cracked exhaust manifolds?? Timing belt? Built to last? Yeah possibly, but i am not sure that it is any better than the V6. I have not heard much reliability/durability issues with the V6...i probably hear more about the V8! :(
More powerful? I don't know...the V6 has more torque output per liter.
And lets be honest...the only reason the 4.7L V8 had an iron engine block was because it is old technology from an old engine dating back to the early 1990's!! The engine dates back to the Lexus LS400 engine. Back then, not many engines use aluminum block because it was too expensive. In other words, Toyota did NOT use the iron block in the 4.7L V8 because it was a stronger/better material, but because there was no other choice! As you notice, all the new Toyota and Lexus engines use ALUMINUM, including the mightly 5.7L V8 on Toyota/Lexus big boys and the upcoming 4.6L V8 in the GX460. So, there is nothing wrong with aluminum as an engine block. In fact, aluminum is a far better material for the engine block than iron because it is lighter, gets rid of heat much better, and can be made as strong as iron with liners (often, iron liners).
I much rather have the timing chain over the long-lasting sparks because i can always replace the OEM sparks with an aftermarket long lasting unit...the same cannot be said about the timing belt. Yeah, i would NOT use the sparks as your argument about the V8 being longer lasting! :D
As for electronics...i don't know...the V6 has VVTi before the V8...and now, the updated V6 (on 2010 4runners) have dual VVTi. You would imagine that the VVTi technology would require sophisticated brain power.
Not on either camp in this argument, but just wanted to point out some viewpoints.:hatsoff:
there is an article dictating that the engineers wanted to use iron because of it's durability and robustness. Furthermore, more output pet liter means jack shit. The v8 is faster has more torque and sounds better. The fact that the v8 uses a belt for for quieter operation and the fact that it has 90k service intervals should hardly take away from the designed life of the engine.
It was cracked manifolds which really isn't a big of deal never cracke blocks.
You have said nothing that makes the v6 better. On paper the v8 is better, it's a very proven platform and bulletproof. It uses no oil and requires only oil changes until 90k.
The fact that it does have a better ignition system means a lot and as I said the simple fact that they didn't put the iridium plugs in v6 speaks worlds of differences.
If Toyota wanted durability, then a timing chain is the way to go. You could argue that Toyota went cheap with the timing belt in the V8. What does the new 5.7L V8 engine on the Lexus LX570 use? Timing chain i believe.
Cracked exhaust manifolds no big deal??!! My brother had to spend over $2000 to fix BOTH sides on his LX470...and he has about 65k miles ONLY! No big deal???? Who are you trying to kid?
Torque per liter is a good indication of how good an engine is engineered. It is equally as important as anything that you have pointed out in your argument about the V8 being better. What does "sound" have to do with anything??!! :D That is pretty ridiculous to say!! :redbrick: And you care more about "sound" than specific output of an engine?! :confused:
Has the V6 been unreliable since 2003?? No. And it is used widely among the 4runners and Tacomas. Not sure about overseas, but I would bet that there are more V6s on the road today than the V8 because 4runners and Tacomas sell at higher volume. Therefore, the V6 has proven itself many times over...so, i don't think that you can call the V6 out on its reliability/durability.
Think of it another way...in 2010, which engine continues on and which engine goes into the trash can?? The 4.0L V6 gets dual VVTi. The 4.7L V8 iron blocked is trashed in favor of a new 4.6L V8. If the 4.7L V8 is so good, then why is Lexus/Toyota getting rid of it in favor a NEW V8 for the GX460?
4.7L V8 2UZ-FE:
My conclusion: At the RPMs typically used when driving, the 4.7 V8 has 25 - 50 ft-lbs more torque than the V6. 5000 RPM? I don't think I've ever had my V8 4Runner wound up that high.
Is the V6 a bad engine? No. But the 4.7 has noticeably more torque, and the difference would be even greater between the V6 and the 4.6 (which is a far newer engine than the now long-in-tooth 4.7).
That's a strawman argument. I've never said the old 4.7 is better than the much newer 4.6. What I've said is that I prefer the 4.7 to the 4.0. And I also prefer the 4.6 to the 4.7.
The great thing about the V8's low end torque is that it accelerates so effortlessly, at low rpm, right off the line, with no need for high rpms. No muss, no fuss, you just scoot.
Perhaps it has to do with the rise in gas prices?
That'd be my best guess. I'm going to try fueling up with premium and see how it goes. I've always done regular unleaded in my V8.
I've done it, I got a whopping 1mpg increase... Performance doesn't feel any different. This was on the highway, not around town.
Did you post in the wrong thread? I was not addressing you. :nono:
One thing that attracted me to the V8 4Runner was the iron block. I've had a few aluminum engines and I just don't like them. I don't think you can consistently get 200k+ miles from aluminum. They are noisier and you have to be really careful about overheating. Probably not an issue for most but I like the iron.
I just love the low end power. It's good for the soul!
Its actually amazing that it can get to about 50mph VERY easily while still keeping the revs around 1700.
Offshorebear, how do you like the KO's after the month or so you've had them? Any power loss - as that is my main concern.
wayblom
